Head work, need to replace base o-rings?
Old Feb 20, 2016 | 08:47 PM
Relentless's Avatar
Relentless
Default Head work, need to replace base o-rings?
A friend and I were disassembling my 2014 SGS 3 weeks ago to get the heads off for some head work. He apparently got confused as to the extent of the job and lifted the rear cylinder up maybe 2" or so. So, do I need to replace the base o-rings on one or both cylinders before I put the heads back on or do you think the o-rings will be fine??? The bike only has about 2000 miles on it. What would you do?
Old Feb 20, 2016 | 10:37 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Replace them. They're not going to put you in the poor house dollar wise.
Old Feb 20, 2016 | 11:44 PM
Relentless's Avatar
Relentless
So slide the cylinders up, pull the pins and remove the cylinders with the pistons still in them, right?
Old Feb 21, 2016 | 05:29 AM
Campy Roadie's Avatar
Campy Roadie
If you decide to lift the cylinder and remove a wrist pin clip and pull the cylinder off with the piston still in it make SURE you cover the bore hole in the case.
I'd replace the wrist pin clip on re-assembly. I've inadvertently lifted cylinders and thought "it'll be ok", only to have an oil seep later.
Old Feb 21, 2016 | 07:08 AM
prodrag1320's Avatar
prodrag1320
the O rings will be fine,if you want replace the small O rings on the oil returns,the large one on the spigot will be fine.dont take the cylinder off,no need to (evo or shovel with gaskets,yes,TC with O rings,no)
Old Feb 21, 2016 | 07:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Have to agree with Kirby. with only 2K on the clock the spigot o-ring should be fine. Your motor your time your money.... your choice. either way won't hurt....
Old Feb 21, 2016 | 12:36 PM
msocko3's Avatar
msocko3
I've had heads off an engine at 20,000 and didn't mess with the O-rings, not a leak to be found. I do however make it a point not to turn the engine over unless I have used a fastener to hold the cylinder down before hand. Maybe I've just gotten lucky.
Old Feb 21, 2016 | 04:13 PM
prodrag1320
Ide be alot more worried about disrupting the rings (witch will happen) than a base leak (witch wont happen)by removing the cylinder just to replace the base o rings
Old Feb 22, 2016 | 06:35 AM
msocko3's Avatar
msocko3
I couldn't agree more.
Old Feb 22, 2016 | 08:42 PM
rgr357's Avatar
rgr357
I replaced cams and head gasket last spring, in process I didn't bolt down the cylinders to keep them from lifting after pulling the heads. Ended up lifting them a bit. Not 2 inches but 1/8 to 1/4,set them back down without replacing & have had no issues with seeping.
JustinF
Engine Mechanical Topics
May 20, 2017 07:36 AM
Bagger_Vance
87
Jun 6, 2015 03:24 PM
inthechateau
Exhaust System Topics
11
Apr 12, 2012 11:54 AM
1931jamesw
Jan 26, 2012 06:08 PM
Meathooks
Feb 26, 2006 01:54 AM
