Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So I want to upgrade my 96 to a 103 on a tight budget. I will be doing the wrench bending and will look to someone else for the tune. I purchased a set of low mile take off 103 jugs and they came with pistons and rings. I have a set of S&S adjustable pushrods, Woods 222 cams that will be going in. I have the tool to remove and install the inner cam bearings. Any other tips, tricks, setup info would be greatly appreciated. The bike this is in is a 2007 Dyna.
Questions I have would be should I use a new set of piston rings, what thickness of head gasket should I use, due to not having compression releases? Also would it be advisable to go with the 103 compensator and heavier clutch spring.
First thing I would do would be to have a qualified machine shop bolt the cylinder up in torque plates and check the piston to cylinder fitment to be sure that fitment is in spec. If so, a quick hone pass to break the cylinder wall glaze and a new set of rings is a must. If not, bore to 98". A .030" MLS head gasket would be a good idea.
If your heads don't have compression releases and you plan on running the 222 cams which have a 34* intake close, you might want to reconsider your cam selection for a cam set with a 38*-40* intake close; say Andrews 57, S&S570 come to mind. Or, have the heads fitted for compression releases.
Heavier clutch spring might hold. If you are not having compensator issues, why replace? If you are going to replace, take a look at the aftermarket, like Baker or if sticking with OEM, replace with the most recent upgrade; I believe there have been 3 or 4; haven't kept up.
Thanks for the input, I currently have a new set of 222 cams, so no going back on the cams. No I'm not having compensator issue, just saw that others were having issues when going to bigger cubes, so if it's not a concern I won't worry about it at this juncture. The cylinders are already at 103, I'm not reusing the 96 jugs so boring to 98 inch is out, they will go on the shelf for back ups.
I understand that you intend to use the 103" (3.875" bore) cylinders. The question for you to consider, or not, is piston to cylinder fitment. You don't know what it is and, perhaps, you don't care but I would want to know before assembling; just honing to break wall glaze will remove some metal. If fitment is tight, you are golden but if a bit sloppy, you can bore you 96" cylinders to properly fit the 103" pistons. Or, you can hone, new rings and take what you get; your call.
With a .030" head gasket, CCP is going to be near 200psi;you might consider having compression releases fitted to help extend battery and starter life. You should also check deck height while you have the chance for future reference. A .040" head gasket will drop CCP to a bit above 190psi; still compression release territory for me but, again, your call.
I 100% agree with what djl said above. All I will add to that is get compression releases no matter which cam you use, Its cheap peace of mind.
Thanks, again, now I understand where your going with your previous statement. Man you just gave more things to think about, not less. LMAO. So off to the machinist I will go, and see what it's going to run to get this thing put to done right and tight.
put the rings in barrels and check what the ring gap is,
IMO if they low mileage, all parts from same engine, ring gap good, hone marks all good in barrels(no lines) then I would give them a sand/stone, clean and assemble
there plenty of young guys building motors from good quality second hand parts and they going fine
Oh, by the way, what are suggestions on a top end gasket kit, cometic, James, hd?
Yes, heavy cross Hatch in the cylinders, my understanding from Trask was that they were new take offs or low mile. I wish I had my pictures I would post them. I will try to post them later if that would help.
Reason: Additional
they not a space shuttle
get comp releases
What would checking the ring gap with the old rings tell? If the cylinders are. 002 out of round (which would be ALOT),it wouldnt show by the ring gap,plus i would never reccomend putting a motor together with used rings.djl has the right idea,if the 103" jugs are not within spec after a light hone to break glaze,bore the 96" jugs to the 103" pistons
