compression ratio for ultra bagger
Old Mar 13, 2016 | 07:49 PM
Lsc8's Avatar
Lsc8
Default compression ratio for ultra bagger
Doing alot of reading on big bore kits. Thinking about it as a winter project..
Curious as to what compression ratio is ideal for a daily ridden 09 ultra? I know that compression should be set for the cam selection.(not sure if im going at this backwards)
I ride 2 up 50% and take a lot of long trips, as well as ride to work almost daily weather permitting.
I ride in the 1800-4000 rpm range.
I don't want anything crazy with some reliability in mind. I'd be happy getting back the lost tq from my cfr mufflers.
Seems reading alot of guys have 10-10.75 cr on the 106/107 kits...which seems high to me on a street bike?
I was looking at something more along the lines of a s&S 106 kit, 89cc heads 9.7-1 cr, and a 570 cam(possibly cyclerama 575?)
Am i way off base?
Old Mar 13, 2016 | 09:35 PM
djl's Avatar
djl
Originally Posted by Lsc8
Doing alot of reading on big bore kits. Thinking about it as a winter project..Curious as to what compression ratio is ideal for a daily ridden 09 ultra? I know that compression should be set for the cam selection.(not sure if im going at this backwards) I ride 2 up 50% and take a lot of long trips, as well as ride to work almost daily weather permitting. I ride in the 1800-4000 rpm range. I don't want anything crazy with some reliability in mind. I'd be happy getting back the lost tq from my cfr mufflers. Seems reading alot of guys have 10-10.75 cr on the 106/107 kits...which seems high to me on a street bike?
Am i way off base?
Not off base but looking at static when you should be looking at corrected CR and CCP. The combination you outlined above might be spot on but you will need to know the dome volume of the S&S piston, head gasket thickness and deck height to accurately calculate corrected CR and CCP. Google the BigBoyz compression calculator and insert the data. Shoot for 9.3-9.6 corrected and/or 190-200psi for CCP. For your application, i.e., long trips and a daily drive 195psi for CCP and/or 9.4 corrected CR should be about right. Both functions of the timing of the intake valve close event. Static CR is just a number, the motor never really sees static as it is operating on dynamic/corrected compression.
http://www.bigboyzheadporting.com/TwinCamComp.htm
You will get varying opinions on this; this one is mine.
Old Mar 13, 2016 | 09:42 PM
Lsc8's Avatar
Lsc8
I've been to big boys website, just not knowledgeable enough to use it.....plugging in various stock numbers corrected cr is 9.45-1 on the cycle Rama 575 and 9.27 on the ss 570. However the Calc also states static comp at 10.06 vs s&s stated 9.7
Old Mar 14, 2016 | 06:21 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Am i way off base?
The Cyclerama .575 would have much more in the rpm range your looking for.
10.0 cr and a set of our Stage II heads with t/body mods will have you producing HUGE useable torque.
See the thread in this section with that combo on a 110" cylinder kit.
Scott
Old Mar 14, 2016 | 06:48 AM
Lsc8's Avatar
Lsc8
Is 10-1 cr obtainable by decking the 89cc heads or .03 head gasket(think it comes with .045)?
i want to replace my heads vs porting because they are high mileage and would need re powdercoated as well as port and polish.
I'm open to other cams as long as I stay lower compression.
1. Its getting harder and harder to find good gas.
2. With the ss heads, its my understanding I need their rocker boxes(or ez start cams) to utilize compression releases.
Old Mar 14, 2016 | 07:18 AM
Hillsidecycle.com
Sponsor
86 cc's, .040" gasket, 107".
Scott
Old Mar 14, 2016 | 08:20 AM
Lsc8's Avatar
Lsc8
So can the 89cc be decked to 86?
Old Mar 17, 2016 | 07:25 AM
Hillsidecycle.com
Sponsor
Sho' nuff.
Scott
Old Mar 17, 2016 | 02:26 PM
Big Money's Avatar
Big Money
107" set at 10.0-1, Hillside Stage 2's, and Andrews 57's. You'll be happy.
Old Mar 17, 2016 | 06:28 PM
cdonis's Avatar
cdonis
Or cr575 cams, with this combo.
