98 ci custom grind cam
Old Jun 21, 2016 | 04:12 PM
fidel's Avatar
fidel
Default 98 ci custom grind cam
98 ci 2000 rk cv 44 carb 48 210 jet 1 washer under l needle s&s e port manifold 2013 head wfo larry stage 1 + massage by j precision 78 cc ,030 gasket
cam custom ground JW performance/Torquepimp grind s&s lifter sm pushrod 0 deck cp flat top piston dtt ignition supertrapp 2 in 1 22 disc closed end cap 3.37 gearing
10.3 static 195 ccp 116.6 tq 110 hp
Old Jun 21, 2016 | 04:53 PM
prodrag1320's Avatar
prodrag1320
Post the sheet
Old Jun 21, 2016 | 06:20 PM
fidel's Avatar
fidel
Default sheet
here it is kirby and by the way its the cp piston i buy from you
thanks
Old Jun 21, 2016 | 06:57 PM
PWMORRIS's Avatar
PWMORRIS
http://www.drdyno.com/
Why did your builder custom grind the cam on a 98" street build and who set up the profile?
Have you ever rode down to your local dealer, or Indy, paid 30 bucks for a pull, and ran it on another dyno? Might be educational to see where you really are...would love to see how his numbers compare to other winpep software...
http://www.drdyno.com/tuningtips.html
Hey, as long as it runs good and you are happy, all good-the Dr. Has many happy customers who appreciate his talents getting their bikes to run at a much more improved level vs. stock.
Old Jun 21, 2016 | 07:54 PM
fidel's Avatar
fidel
john walker custom grind cam profile and its the first time on the dyno im sure put it on another but the butt dyno say good difference between previous build which is same bike cv 40 andrews 57 cam make 107 tq 98 hp on 2 different dyno almost same number + or less 2
fidel
Dyno Charts
Jan 16, 2017 12:20 PM
LowriderHarold
EVO
Apr 8, 2014 02:31 PM
fidel
Feb 5, 2013 09:09 AM
hdrider53
Exhaust System Topics
Nov 21, 2010 11:44 AM
rel3rd
Jul 13, 2010 08:16 PM
