Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Almost ready for the cam install, just need lifters. Any recommendations?
Here's what I got so far:
Andrews 37G cams
Gear kit
Gasket install kit, bearings Rockout kit
Thanks man
Lifters... I use S&S standards. You just never hear a bad comment about them.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
