Tensioner replacment signs
Old Aug 21, 2016 | 07:42 PM
markwolula's Avatar
markwolula
Default Tensioner replacment signs
I am not going to invent the wheel again... We know what they are, and the problems that they can cause... We know the older style are spring , and the newer are Hydraulic.. We know the hydraulic were an improvement ....
Consensus is , remove cam cover and cam plate to inspect and check properly.. This entails , remove right floorboard,, exhaust system,, remove or cut pushrods,,gaskets etc.. I know you can use a dental mirror to get an idea of the rear tensioner,, but it still is some work if you find there ok to reasonable...
Question is,,,
Bike has hydraulic tensioners, (2009 E/G),,, 70,000 miles,,, Oil change at 3,500 miles,,, Always cut and check oil filter at every oil change ,,, No yellow plastic debris found in oil filter ...
Is this enough of a preventative maintenance measure, than going in and removing parts , etc ,, ?????
Old Aug 21, 2016 | 08:03 PM
HDmikie's Avatar
HDmikie
Damn, it sure wouldn't hurt to at least pull the cam cover and peak in there. Not hard to do, but put a pan underneath to catch the cup of oil that will run out. JMO
Old Aug 21, 2016 | 08:41 PM
Campy Roadie's Avatar
Campy Roadie
You can't see the back tensioner with the cam plate installed (hydros).
Old Aug 21, 2016 | 08:45 PM
SamStone's Avatar
SamStone
I didn't think we had to worry about the upgraded tensioners. I paid $1300 for the upgrade and the mother****ing motor company screwed me again?
Old Aug 22, 2016 | 07:28 AM
Campy Roadie
I wouldn't go that far, BUT......the "conversion" kit only replaces the outside chain with roller chain. The inside chain retains the silent link chain which is hard on tensioners. A better fix is roller chains inside and out but you have to have conversion cams for that.
All that said, I think you're somewhat better off with the conversion over a stock spring set up. With spring tensioners and Cyco shoes you're about even with the conversion kit.
Old Aug 22, 2016 | 08:13 AM
HDmikie's Avatar
HDmikie
True dat.....but with 70,000 miles you could at least see the outer tensioner and if that one is badly worn, you can be fairly assured that the inner tensioner is close to failing. JMO
Old Aug 22, 2016 | 09:20 AM
djl's Avatar
djl
Order a new set of tensioners; CYCO now offers a tensioner with better material for the later models and there is the Zippers dual piston tensioner if you want to spend more. At 70K miles, if going to the trouble to open up the cam chest and check wear, might as well replace and forget about them for another 70K miles. The later model tensioners are much improved over the early spring loaded type but, like brake pads, still a consumable part that requires maintenance........
EDIT: Agree with Nomadmax. Although the lifters are the HD "B" lifter, good hardware, they are getting tired at 70K miles. For $65 to your door, you can get a set of CompCams VThunder 850-1 lifters or spend $125 for a set of S&S standards.
Old Aug 22, 2016 | 09:35 AM
Campy Roadie
I'm with DJL on that. If I have to open it up, I'm gonna open it up. At 70k miles on a modern HD the lifters could use replacing anyway. Take off the rocker covers, lift the rocker assembly, remove push rods/tubes, remove lifter blocks and lifters. Sounds like a lot of work but it isn't.
Old Aug 22, 2016 | 11:03 PM
markwolula's Avatar
markwolula
Thanks for your responses .... I understand the work involved to dismantle/ install parts to cam chest area.. You could include cam bearings ,, oil pump,, etc...
What I was after though, was ,, Peoples experience, (that cut open their oil filters)... Did they find any cam tensioner debris in their oil filter, and was this was their major reason they pulled cam chest for inspection,, and found tensioners required changing,, with whatever mileage was on their bike ??? .. Or, people that inspect their oil filter, found nothing , but after pulling cam chest, found the tensioners needed replacing.. ie, debunking the idea that cutting open your oil filter can give you pre warning that cam tensioners need inspection , and or replacing....
Of course , if a bike was getting upto the 60-70,000 miles, and you had the exhaust system off, (for whatever reason),, you would, (for peace of mind), remove the cam cover to have a peak in there to get an idea how they are going,,, even if you were a "cut open the oil filter type of person", ...
cajun1957a
Jun 29, 2016 09:02 AM
brckss2
Engine Mechanical Topics
14
Jan 9, 2016 03:31 PM
Bohemian
Mar 15, 2015 10:57 AM
Yachtman
Jul 26, 2009 08:41 AM
Okoman
Sep 11, 2008 09:10 PM
