Twin-Cam Oiling Question
Heritage Springer Softail...
My questions are is it normal to see visibly darker oil when you pull cam cover off, then what you see in the oil tank?
Bike is meticulously maintained, I change the oil & filter every 1500 miles and I only have a little over 17,000 miles on it, I have never had a lick of trouble with it...
What prompted me to pull the cam cover off was I ran across the following...
http://www.jamesrussellpublishing.bi...buyharley.html
Which gave me a significant amount of concern...
When I pulled off my cam cover to take a gander at the timing chain & followers the 15 thousand mile scare stories the internet warns us about; I found everything looking perfect at this point...
The only thing anomalous I noticed was that the oil was visibly darker than I thought it should be given I changed it about 500 miles ago...
I compared it to what is in the oil tank and the oil in tank is definitely not as dark...
Looking in bright sunlight I see nothing shinny, so I don't think there is any metal going through the system...
So I'm wondering IF this is NOT NORMAL, than do I have some kind of oil pump spring, pressure valve or related problem?
Or?
Lastly, anybody have a recommendation based on personal experience on a twin-cam gear drive & camshaft kit upgrade to get you away from the chain & follower issues?
Applicable usage... I have no intention of making a hot-rod out of this one, I want to keep it reliable & long living and good for going to Sturgis or the grocery store for a cold 40...
Thanks in advance.
Or?
Thanks in advance.
Not sure why the oil left in the cam chest would be darker....
How much oil was left in the cam chest? A small amount is normal, too much oil left in the cam chest suggests wet sumping. Some causes of wet sumping are; rocker box umbrella valves stuck/worn out, seal on oil pump and scavenge hole misaligned, pinched o-ring on cam plate, oil pump damaged/worn out. At your mileage & without ever having removed your cam plate, most of these should not be an issue.
Andrews makes some great gear driven cams that would get rid of the chain/tensioners all together... but you need to check your crank runout first to make sure your engine is a good candidate for gear driven cams. I think anything over .004 crank runout and the gear drives of the cams will self-destruct over time...
You could always do the SE cam plate upgrade, switching to hydraulic tensioners v spring loaded tensioners. The SE upgrade only has a roller chain on the front of the cam plate... many have done this SE plate upgrade and say the switch to hydraulic tensioners was more important than two roller chains.....
I have an '03 and will be digging into the cam chest in the near future. I will either do the SE cam plate upgrade or do a conversion cam changeover to the newer style cam plate (with dual roller chains).....
Good luck...
