Flywheel markings
Old Oct 20, 2016 | 09:22 PM
Jonk777's Avatar
Jonk777
2nd Gear
Thumbs up Flywheel markings
Hello to all. I wanted to know if you can set the timming on a 1990 evo at the Tdc mark using a duel fire electronic ignition. By putting the tdc mark to the right of the timming hole and adjusting the module in the nose cone.
Old Oct 21, 2016 | 06:16 AM
prodrag1320's Avatar
prodrag1320
why not just use the advance timing mark?
Old Oct 23, 2016 | 03:39 PM
grbrown's Avatar
grbrown
Time it as per your factory service manual!
Old Oct 27, 2016 | 09:28 AM
Max Headflow's Avatar
Max Headflow
If it a crane, DTT, Dynatech with LEDs, you can time it that way.. I usually check by rotating the crank with the bike in gear to make sure of the position where the LED goes out..
Bill wallace
Shovelhead
Oct 1, 2016 10:00 PM
RidemyEVO
EVO
Apr 28, 2015 07:03 AM
traildog
EVO
33
May 18, 2014 10:22 PM
novice47
Mar 2, 2011 10:02 AM
steventh
Jan 1, 2007 04:58 PM
