Lifter confusion
Old Dec 21, 2016 | 10:41 PM
65Tiger's Avatar
65Tiger
Default Lifter confusion
I need new lifters for a Woods 777 cam installation in an 08 RK and the mind boggles at the choices. Spring pressure is stock
Who is Cyco and are they any good?
Is the practice of using a SBC lifter frowned upon? I read conflicting information that it is a repackaged Crane to an S&S video showing that it takes 2 min. for SBC VS stock lifters at 45 sec. for oil to reach the top end - not sure what SBC lifter they used
Stock B VS C......... the choices go on and on
My stock lifter is a 183538-99B
The safe route seems S&S "high performance" or stock, but am interested in what the differences are, if any, given the limited number of manufactures and ways to skin a cat.
Old Dec 22, 2016 | 01:12 AM
2009blackpearle's Avatar
2009blackpearle
your 99b lifter isn't available any more the newer 99c are garbage made in mexico crap . they bleed down and clatter like crazy. think s-s or woods are your best bets now and from post I see about lifters most of the builder recommend going .130 on pushrod adjustment after 0 lash.
Old Dec 22, 2016 | 02:02 AM
Little Mike's Avatar
Little Mike
As stated the 99B lifter is no longer available and the 99C have a bad reputation. The Woods consistently get good reviews but are pricey. If you decide to go with S&S do some research and start with their website. You will pretty quickly notice what is highly touted about the Premiums but not-so-much about the standards. Might explain why they cost half as much. Message me if you'd like more info on that. There are also Hylift-Johnson which are US made and can be gotten here...http://www.larrysmotorcyclemachine.com/. He's also a forum member and very knowledgeable.
Old Dec 22, 2016 | 03:00 AM
65Tiger's Avatar
65Tiger
I did not even check with S&S and assumed that High Performance was just that - apparently there is something higher
Will contact Larry as suggested
Old Dec 22, 2016 | 06:06 AM
prodrag1320's Avatar
prodrag1320
get the S&S standards,best lifters hands down.we use them on most builds with 0 problems or failures (& we use ALOT of them)
Old Dec 22, 2016 | 11:15 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The difference in SBC and S&S standards is in the size of the oil port in the lifter body and how quickly the lifter pumps and gets to the top end. Hands down the standards are a great worry free product.....
Old Dec 23, 2016 | 03:34 PM
djl's Avatar
djl
The difference in SBC and S&S strandards isinnthesize of the oil pet in the letter body's how quickly the lifter pumps and gets to the top end. Hands down the standards are a great worry free product.....
Pretty sure the oil port in the lifter bodies are the same. The difference is in the hole in the piddle valve; SBC is smaller. Some run the SBC lifter but change out the piddle valve from a set of used HD lifters.
Old Dec 24, 2016 | 04:59 AM
2013_FLHTK's Avatar
2013_FLHTK
I'd still buy the S&S lifters but your post and picture really shows the difference. Definitely good info for those on a tight budget.
Old Dec 25, 2016 | 01:28 AM
65Tiger's Avatar
65Tiger
Is that because we run 20-50 or even heavier oil rather than 10-30 or even lighter?
I have always wondered why 20-50, 50, or even 60 given modern synthetic oils ability to maintain viscosity at high temperatures and how our bottom ends are made.
Here comes the oil thread!
Old Dec 25, 2016 | 01:29 AM
65Tiger's Avatar
65Tiger
The Johnston Highlift ones from Larry referenced above are only 30.00 more expensive than SBC from Summit
