Can tensioners
Old Jan 27, 2017 | 04:16 PM
Jim18919's Avatar
Jim18919
2nd Gear
Default Can tensioners
It's time for me to replace the cam tensioners. I have an 03 Electra glide. Which is the best way to go? Do I go with gears or just get the hydraulic tensioner put in?
Old Jan 27, 2017 | 04:24 PM
QC's Avatar
QC
How many miles are on it? How many miles do plan to keep it? Any further engine mods?
If no further engine mods, my suggestion would be to replace with Cyco tensioner pads.
https://www.google.com/url?sa=t&rct=...z5pM-B4_X-pWgA
Old Jan 27, 2017 | 05:00 PM
Eastcoast Jim's Avatar
Eastcoast Jim
Gears are the best - - but only if the run out is good & you are planning on keeping it - you will need new cams & spend much more money
other wise the cyco pads
Eastcoast Jim
Old Jan 27, 2017 | 05:30 PM
DonnieM's Avatar
DonnieM
I just did my '06 Ultra with Cyco shoes and put a cam in while I was in there. Change the inner cam bearings when you do it. Added a Baisley oil relief spring and brought the oil pressure up a bit. Worked for me and I was happy
Old Jan 27, 2017 | 06:18 PM
djl's Avatar
djl
Spend the money on a set of S&S 509 cams and do what DonnieM did instead of spending money on parts you don't need to have a good running dependable motor.
Aa cost effective solution and increases performance as well. If the bike is carbed, you will probably need to rejet; I assume Stage I upgrade has been done? If not, you should do that while you are at it. If the bike is EFI, you might consider a fuel management system as well. Money better spent there than on gears or hydraulic tensioners.
Old Jan 27, 2017 | 07:51 PM
REW13's Avatar
REW13
My work was done a few months ago, I went gears with andrews 37 cams, new high flow oil pump, adjustable push rods and ofcourse new bearings.. major difference in power gained too.
LQQK_OUT
Engine Mechanical Topics
Sep 24, 2018 09:44 AM
Rastoff
General Topics/Tech Tips
Mar 23, 2016 11:39 AM
ravens9322
Apr 16, 2015 02:01 PM
jmn1960
Jul 4, 2014 06:34 AM
simpkinst
Exhaust System Topics
Mar 25, 2011 02:41 PM
