Rocker Box
Old Apr 3, 2017 | 10:05 AM
Lunchboxx's Avatar
Lunchboxx
Default Rocker Box
2001 Road Glie TC88
A while back I noticed oil coming out from the rocker box gaskets. I replaced them and all was good for about a month or so. Now the rear cylinder is leaking out the gasket again. could the breathers be plugged or what else should I check. I took off the upper rocker box cover cleaned it up and retorqued the bolts but its still leaking. Any ideas?
Old Apr 6, 2017 | 10:28 AM
bad tappets's Avatar
bad tappets
Leaking from upper or lower gaskets? Check to make sure all the breather parts are clear. You can enlarge the drain holes in the rocker arm support plate. Did you clean the bolt holes out and use blue locktite when reassembling? Did you follow the proper tightening/torque sequence? If you replaced the lower gasket, did you install it correctly? Installing it flip/flopped will block the breather passage.
Hope this helps.
Old Apr 6, 2017 | 11:51 AM
Lunchboxx's Avatar
Lunchboxx
The answer to all of those is yes. Except I am not sure if the lower gasket was placed correctly.(rear cylinder) I know the front one was place correctly. and its leaking on the rear so I am gonna pull my tank again and check it all out.
Steevo12683
Engine Mechanical Topics
Aug 4, 2017 07:23 PM
Jordan.2216
36
Apr 9, 2016 12:11 AM
dsturch1
Aug 10, 2014 06:43 PM
Roni
Aug 17, 2013 01:01 AM
biodog77
Mar 21, 2011 06:10 AM
