Dynoed the build!
Old Apr 12, 2017 | 03:42 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Sounds good!
Scott
Old Apr 12, 2017 | 04:59 PM
djl's Avatar
djl
Originally Posted by SJ12DS
Now I think my compensator is going. Too much power for the stock unit? Getting some hot start starter kickback. Any recommendations for which comp to replace it with. SE? Baker? Something different?
Thanks.
Early compensator; they hardly ever go bad. Doubt that too much power is the issue. My '02 FLHT is powered by an all bore 107" motor that makes 124TQ/110HP and the compensator has not shown any issue for 10K miles. The early compensators did have an issue with the comp nut being a tad too long to develop sufficient clamping pressure when the nut was torqued to spec and the nut would come loose. The fix was to remove the nut and shave .030" off the end of the nut. Check the attachment for clarification.
The Bellville springs can get weak and the old school fix for that is to find an old compensator, cannibalize a spring and add it to the weak spring pack. But if you think you have to replace the compensator, best bet is to replace it with another OEM unit.
Old Apr 12, 2017 | 07:00 PM
SJ12DS's Avatar
SJ12DS
Thanks for the info. So my stock unit should handle the torque?
What else should I check?
Thanks again.
Old Apr 12, 2017 | 07:26 PM
SJ12DS's Avatar
SJ12DS
Now that you mention it, I thought I read somewhere that the 05 year had trouble with the nut coming loose and the fix was to add a washer and re-torque. Does this sound right? Also Do you know if they changed the torque procedure.
Somewhere I heard that the new procedure was to torque to 75ft lbs and the add 45-50*. Does not sound good to me.
Old Apr 12, 2017 | 08:49 PM
djl's Avatar
djl
Now that you mention it, I thought I read somewhere that the 05 year had trouble with the nut coming loose and the fix was to add a washer and re-torque. Does this sound right? Also Do you know if they changed the torque procedure. Somewhere I heard that the new procedure was to torque to 75ft lbs and the add 45-50*. Does not sound good to me.
Tech bulletin issued for '03-'05 models, torque to 70 ft.lb. and add 45* which will require at least 150 ft.lb. to 165 ft. lbs. IIRC, the service manual form my '02 requires torqueing to 150 or 165 ft.lbs.; can't remember which but torqued straight to that number without the 45* bit. If you think the noise is coming from the compensator, pull the outer primary and put a torque wrench on the comp not and see what you get; you will need a long 1/2" torque wrench; 150 ft.lb. is a but buster.
If it is loose, remove the nut and shave .030" off the end or go insert a .030" shim (both are shown in the diagram previously posted but you don't need both; one or the other). The MoCo sold shims for this purpose in several different thicknesses, up to 090" IIRC. Check with the parts guys at the dealer but unless they are older guys, they won't know what you are talking about. Find a machine shop and shorten the nut .030", clean the threads and use a couple off drops of red Loctite and torque per the procedure.
If the comp is tight, start looking elsewhere.
Old Apr 12, 2017 | 09:07 PM
SJ12DS's Avatar
SJ12DS
Thanks for the info and advice.
Old Apr 12, 2017 | 09:33 PM
djl's Avatar
djl
Forgot to add that it will hold up to the torque. Mine is holding up fine under 124TQ.
Old Apr 13, 2017 | 10:55 AM
SJ12DS's Avatar
SJ12DS
Good to know.
So I took the primary cover off today and the compensator nut was loose. Not excessively but it was easy enough to loosen it.
I guess I caught it in time.
Well here is the issue with my compensator: There is no spring between the two pieces with the interlocking teeth. Is this correct? Also in the service manual it shows the exploded view and there is no spring in the picture.
I know the 03s needed the shim or some shaved of the nut to get better clamping force but does that apply to 05s? I would think that by 05 they would have made the nut shorter to allow it to clamp properly.
I have the new torqueing procedure TSB M-1170.
Thanks again for all your help.
Old Apr 13, 2017 | 12:52 PM
djl's Avatar
djl
Good to know. So I took the primary cover off today and the compensator nut was loose. Not excessively but it was easy enough to loosen it. I guess I caught it in time. Well here is the issue with my compensator: There is no spring between the two pieces with the interlocking teeth. Is this correct? Also in the service manual it shows the exploded view and there is no spring in the picture.
I know the 03s needed the shim or some shaved of the nut to get better clamping force but does that apply to 05s? I would think that by 05 they would have made the nut shorter to allow it to clamp properly. I have the new torqueing procedure TSB M-1170. Thanks again for all your help.
All early compensators are the same; all were subject to coming loose. You don't really thing the MoCo would spend the money to shorten the nut by .030" do you? As you can see in the attachment, no spring between the sliding cam and the cover. You might get away with cleaning the threads, apply a couple of drops of red Loctite and torque per procedure but I would shave .030"-.050" off the nut to insure that it can't come loose in the future.
There were three different thickness shims, .030", .060" and .090". The PN for the .060" is 24032-70 and for the .090" is 24033-70 and I have lost the PN for the .030" shim. I think it is a moot point as those PNs are now obsolete and it would be akin to winning the lottery if you found a dealer that had one of either thickness in stock but might be worth a try. You would be much better off shaving down the nut.
Old Apr 13, 2017 | 01:09 PM
aquadave's Avatar
aquadave
my 2 cents which in todays exchange rate is worth about a penny. He has a nice smooth bottom- mid range, i think looks real good. I don't know how big his wife/ girlfriend is so I can't say if he needs more torque or not. I'd rather run rich than lean. Lean gets hot and i'd rather change spark plugs than pistons. And it's a new build in break-in all the more reason to run rich
sharkey
Apr 2, 2014 09:46 PM
ral819
Aug 1, 2013 09:26 AM
mgmmgm
Aug 28, 2012 08:01 PM
Druid
Feb 15, 2012 04:40 PM
harleytuner
Jul 28, 2010 03:19 AM
