S&S HL2T Lifters????
Old May 30, 2017 | 08:15 PM
micalaut's Avatar
micalaut
Default S&S HL2T Lifters????
So here is my dilemma, I have had my 2011 103" Limited motor rebuilt from the crankshaft up and bored out to a 107. I did the removal and install of the motor and the cam chest work. I was pleased to find a Fueling cam plate and these S&S premium lifters stamped with HL2T on the side in the motor when I took it apart. Going back together I downloaded the instructions for the lifters from the S&S web site. After adjusting the rear cylinder pushrods to zero lash and then another .125 , I let them sit and after 25 minutes both intake and exhaust go back to zero lash pretty much like a standard lifter. I move to the front cylinder and repeat the process and after my 25 minute wait same results on the front cylinder. I spun the motor slowly with the back tire when I was done , didn't hear or feel anything abnormal so I continued with the assembly and eventually fired it up to an instant start up of the motor. I had a couple seconds of rattling which I figured were lifters and pushrods and rockers
filling up and everything seems normal, I have since put about 60 miles on according to break in recommendations. Is it possible that the travel limiters in the lifters were removed or did S&S make these with out the limiters?? Any one with experience with these. The motor is smooth and quiet I am just concerned about the adjustment.
Old May 31, 2017 | 05:46 AM
joe40x's Avatar
joe40x
I just installed a set also that were marked HL2T. They didn't have limiters in them either. I wouldn't worry about it...you don't really need them for a 107.
Old May 31, 2017 | 06:33 AM
prodrag1320's Avatar
prodrag1320
you can order them either way.BTW,CID isn't the determining factor for limiters,cam choice & how high the motor will be RPM`d is
Old May 31, 2017 | 11:33 AM
98hotrodfatboy's Avatar
98hotrodfatboy
There's no way there are travel limiters in there if you set the preload to .0125". The limiters themselves are .100" thick and the lifters only have .200" total travel... Valve piston would have happened. You can always disassemble one to find out.... Plus you don't need them on the street.....
Old May 31, 2017 | 06:46 PM
PWMORRIS's Avatar
PWMORRIS
This^^^^^^^^^
Old Jun 2, 2017 | 11:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We use a ton of the S&S Standard lifter.
Non-limiter premiums on the shelf for the folks that request them.
Scott
TroubledWine
Engine Mechanical Topics
May 9, 2018 04:26 PM
fergerburger
Shovelhead
Sep 25, 2017 04:33 PM
Garand36
23
Sep 17, 2015 02:53 PM
pittz5
Apr 11, 2015 08:09 AM
gottahavvitt
EVO
Feb 17, 2008 02:09 PM
