Help/advice needed: 95" motor on its last legs. What's the next move?
My question is, what should I do? I would like to split the cases and do a 103 stroke motor since I have 103 heads, and the 95 and 103 share the same bore size and my crank needs to be replaced anyway. I am on a budget and don't want to go crazy but I'm not a cheap skate either. I would want to reuse as much parts as possible, thinking the only new things I would need to get is the crank, Pistons/rings/clips, highflow cam plate/oil pump, and whatever gaskets/bearings need to be replaced.Any input is appreciated
Of course I hope the crank is not knocking, bur the bike does have a lot of miles on the bottom end, a rebuild is coming whether I like it or not. If it did come to splitting cases, what's the route to go? I was thinking of getting a 103" or 96" crank (I believe they both have the same stroke) and using my existing cylinders/heads/pushrods with new pistons. What came plate do I use? Can I still re use my Andrews cams designed for a 88" bike? Just a lot of questions as I cant want to spend 3k on a name brand stroker kit
You can't replace your '01 crank, which is the best the MoCo has made; the HD replacement will be of a lesser quality IMHO. You can have the '01 crank serviced by Hoban Brothers for about $500 IIRC; no truing or balancing but refurbishing to "like new" condition. Not my money but spending another $600 will get you a trued, balanced and plugged 4.375" crank. You already have the Timken left side bearing which Hoban will replace as well as the other crank bearings. A set of the new bolt in HD 4" cylinders and pistons will go on without case boring and you are now looking at a 110" motor.
There are several cam plate options but, again, JMHO, the '01 OEM cam plate with new outer bearings and new pump will work just fine. If more pump capacity is desired, Daytona offers a higher capacity pump for about $125 on Ebay.
Again, JMHO, but the cams you are running in the "old" motor, should probably be replaced with cams more suited for the larger displacement motor. Cylinder heads will be OK as is but, again, mo money, head work will only compliment the displacement upgrade.
So, the way forward depends on your goals and budget but, as has been said, it would be wise to be sure that the noise you are hearing is coming from the lower unit.
So what could the sound be from? I hope it's just a loose wrist pin. I certainly don't want to split the cases, and hope it's an easy fix like that. If it's not, are there any other "easy fixes" I could do before a new crank?
