Shovelhead stroker PLEASE help!
Old Jun 15, 2017 | 11:06 PM
hombrekid's Avatar
hombrekid
6th Gear
Default Shovelhead stroker PLEASE help!
Hello all.
Ive recently acquired a motor and have a question. It's got Delcron cases, Axtell Jugs, JE pistons, shovelheads stamped 77. It's got 3.8125 bore and 4.5 stroke. I'm tearing into it because I wasn't sure what I had and just wanted to touch it all and check for wear and all that. So tonight I pulled the jugs off and there's no base gaskets??? I've heard of guys not using any base gaskets for more hp?? So my question is this. I feel like I should use base gaskets when reassembling but in doing so what will I be gaining or losing?? I really just don't want to f... anything up. Any and all input is greatly appreciated!!
Old Jun 16, 2017 | 06:05 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Unless your racing it's not worth not using them..... Crank case pressure will make oil seep out.... I'm sure someone makes a .010" gasket...
Old Jun 16, 2017 | 06:11 AM
touchdown's Avatar
touchdown
very interesting Question, Thinking of two things. First no base gasket for HP??? Im sure there something is used in place like maybe some gasket sealer, another thing I like a gasket but I would check the stroke to make sure the piston don't top out and thats the only reason for more HP I can think of. Good luck
Old Jun 16, 2017 | 06:29 AM
prodrag1320's Avatar
prodrag1320
if there both a good surface,you can just use sealant (NOT yamabond!!),use a anorobic type sealant
Old Jun 16, 2017 | 11:29 AM
hombrekid's Avatar
hombrekid
6th Gear
right on. All good information. There did seem to be some very light residue. .010 is the answer.
are6rider
Engine Mechanical Topics
Feb 26, 2016 10:15 AM
Bullys FLSTN
Exhaust System Topics
Apr 24, 2012 06:36 PM
voodoodrug
Jul 8, 2010 10:27 AM
sicshovel
Mar 1, 2010 08:06 AM
jims95sg
Sep 12, 2008 08:05 PM
