08 flhx
Old Jun 17, 2017 | 09:38 PM
Streetglide8208's Avatar
Streetglide8208
Stage I
Default 08 flhx
Ok I've got a 08 street glide factory came with a 96 vin # on bike and motor say 96. But derby cover say 103 so does air filter cover and has a dyno fuel pack. So my question is how can I tell if my motor has been upgraded to a 103 from a 95?
Old Jun 17, 2017 | 09:47 PM
brad75raiders's Avatar
brad75raiders
Pull the head and measure the bore
Old Jun 19, 2017 | 05:33 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Brads suggestion would be the most straightforward approach.
Scott
Old Jun 20, 2017 | 09:38 AM
djl's Avatar
djl
IIRC, the 103" motor was not available in the FLHX until 2011 with the PowerPak option; probably a 96" motor. However, if you suspect different, check static compression. The 96" motor should see about 180psi and the 103" motor should see about 190psi, both at sea level so adjust as required. Numbers may be off a bit depending on gauge, test procedure, battery condition, etc. but the point being that the 103" motor will put up higher static numbers than the smaller bore 96" motor. Still betting it's a 96" motor though.
Old Jun 20, 2017 | 09:56 AM
Iceman24's Avatar
Iceman24
Didn't you get anything from PO, or was this bike purchased at dealer? Could just be someone got ahold of 103cu/in covers and swapped on your 96cu/in bike to lead others into "thinking" it was a 103. Hope it wasn't highlighted as perk in your purchase...
Pappy1
Jan 27, 2014 09:04 PM
cmcoyner
Oct 10, 2013 06:26 PM
Fire-Medic
Touring Parts
Jan 9, 2013 04:54 AM
dartpro1
Exhaust System Topics
11
May 3, 2012 06:17 PM
PDDGM
Jan 26, 2011 03:54 PM
