motor question
Old May 1, 2012 | 10:03 AM
dartpro1's Avatar
dartpro1
Default motor question
Ok my buddy has a 06 fhlx and I have a 2011 flhx.... Will my 96 inch pistons, jugs and heads work on 88 inch motor with out machining the cases?
Old May 1, 2012 | 10:18 AM
Shredding rubber's Avatar
Shredding rubber
An 88 and a 96 are the same bore,the 96 has a longer stroke
Old May 1, 2012 | 10:47 AM
dartpro1's Avatar
dartpro1
Ok thanks
Old May 1, 2012 | 12:21 PM
djl's Avatar
djl
Cylinders and heads, yes; pistons no. As pointed out the longer 96" stroke requires a different piston.
Old May 1, 2012 | 06:42 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
No, but your bud can bore his cylinders to 98".
Wiesco manufactures a piston/gasket kit for us.
Scott
Old May 1, 2012 | 08:23 PM
Dbstglide's Avatar
Dbstglide
Also have to do a conversion for the upper motor mount...
Old May 2, 2012 | 05:43 AM
Hillsidecycle.com
Sponsor
Yes we have machined the f/head now, on several occasions, for those.
Scott
Old May 2, 2012 | 05:49 AM
dartpro1's Avatar
dartpro1
He was trying to stay away from machining the cases... That would have to be a winter project like my 113 was...
Old May 3, 2012 | 05:26 AM
Hillsidecycle.com
Sponsor
No case machining required, to bore the cylinders to 98".
Scott
Old May 3, 2012 | 05:33 AM
Shredding rubber
Hey Scott. What's the biggest bore an 88 can get without machining cases.
Thanks
