107 build
Old Aug 6, 2017 | 09:04 AM
eross318's Avatar
eross318
Default 107 build
I just put down a deposit for a 107 build from Pure Powersports. I need some help deciding on what cam to use. I can choose from Fueling, Zipper, Andrews or S&S cams. CR will be 10.25 or 10.5. I might also go with their stage 2 heads. I ride mostly 1 up, 2up occasionally. Looking for something with some good low end torque that wont fall off to early. Bike is 2014 Ultra Classic. Thanks
Old Aug 8, 2017 | 07:59 AM
northeastconfederate's Avatar
I don't have experience with it, but like the looks of the S&S 570. It should make a good bagger cam at 10.25 or so CR. Whatever you choose, my suggestion is to make sure the intake valve closes at or before approximately 40° to ensure the torque comes on early.
Your pipe will have a big impact on this as well.
I run TMan 625 cams (41° int close) in my all bore 107. It has a broad, flat torque curve that comes on nice and early. I love it.
Old Aug 8, 2017 | 08:09 AM
Deleted post
Old Aug 8, 2017 | 08:12 AM
Deleted post
Old Aug 8, 2017 | 03:22 PM
seanl's Avatar
seanl
Based on your intended use, what did Pure Powersports recommend?
I'm also planning a 107 upgrade for my RKC and have about the same requirements as you, mostly 1 up with good bottom end and enough top end to keep it interesting. My plan is a 10.25CR Fuel Moto 107 with stock heads, this will match up nicely with the Wood 555 cam that I had installed earlier this summer.
Old Aug 8, 2017 | 05:42 PM
prodrag1320's Avatar
prodrag1320
S&S .570,I'm hoping your planning on some headwork too.
Old Aug 8, 2017 | 07:36 PM
eross318's Avatar
eross318
They recommended the reaper 574 Im also getting a set of there heads to go with it at 10.5 cr. They have some nice charts on their facebook page with that set up. Im still up in the air about the cam.
Yes IIm getting head work done with it
Old Aug 11, 2017 | 09:27 AM
eaglefan1's Avatar
eaglefan1
Go to the tech forum and search cycleRama 570 or 575 cams. Super impressive curves on the dyno sheets. Shaffer performance is a place that uses a lot of those cams and I think he is up there by you. Darren is the guys name and I messaged him frequently with questions and he gave me answers from his experience with those cams. Basically why I choose the CR 575.
His dyno sheets that he posts are some of the smoothest flattest lines I have ever seen
Old Aug 11, 2017 | 07:51 PM
brad75raiders's Avatar
brad75raiders
I have a 107 kit with heads cam tbody pistons and barrels all new if anyone is looking i am buying a FXR and will put the $$ into it
Old Aug 12, 2017 | 05:47 PM
ntraindavefl's Avatar
ntraindavefl
Maybe you have already but try posting this in the classifieds for better luck. While you're at it send me some photos of the kit just in case I'm interested
