new 107 Hillside build coming
2008-up is 4.2g (TBW). That covers to 110 bikes.
With the mods and likely large cams you'll run, a 5.3 would be better, IMHO.
https://www.fiveomotorsport.com/56010us450-42lbs/hr
Screamin Eagle makes larger injectors they use on their Race 124:
Screamin' Eagle Ž Pro High-Flow Injector Kit
Injectors provide fuel delivery at the rate of 6.2 grams/second, 59% more than
the Original Equipment injectors. Recommended for use with engine configurations
making more than 120 rear wheel horsepower. All EFI-equipped models
require ECM calibration (sold separately). For race application only.
27400002
Fits Twin Cam models equipped with Screamin' Eagle Pro 62mm EFI Throttle
Body 27300019 with High Flow Oval Port Intake Manifold P/N 27082-10 or
Screamin' Eagle Pro 58mm Throttle Body P/N 27639-07A with High Flow Intake
Manifold P/N 29667-07.
Screamin' Eagle Pro High-Flow Injector Kit
Injectors provide fuel delivery at the rate of 6.7 grams/second, 56% more than
27400001
Fits '08-later Touring models equipped with Screamin' Eagle Pro 64mm Throttle
Body P/N 27300033 with High Flow Oval Port Intake Manifold
mine is a 124 using 110 heads, when I got into doing any machine work I had been talking with scott and wes on my first build. (107) and went with Scott he was closer to me living in new York . so I decided on this build to give wes a try seeing that he makes great cams that produce great results!
