SST static street compression lol!
Old Sep 2, 2017 | 09:56 PM
Clayton24's Avatar
Clayton24
Default SSC static street compression lol!
Im just wondering how much static compression i can get a way with on a street touring 103 limited twin cooled with 93 octane pump gas with no issues ? I appreciate any and all help thanks to all. Sorry i meant SSC not SST in the title it was a joke !
Old Sep 3, 2017 | 01:02 AM
rhuff's Avatar
rhuff
More importantly would be your CCP. I think many who know much more than I would say about 190 CCP for reliable, no problems touring. Play around with bigboyz calculator.
My 03 RKC is around 200-205 CCP (10.83 static). Occasionally, it gets a little b!tchy with hot re-starts, but the tune is spot on.
Old Sep 3, 2017 | 01:23 AM
Clayton24's Avatar
Clayton24
[QUOTE=rhuff;16597308]More importantly would be your CCP. I think many who know much more than I would say about 190 CCP for reliable, no problems touring. Play around with bigboyz calculator.
My 03 RKC is around 200-205 CCP (10.83 static). Occasionally, it gets a little b!tchy with hot re-starts, but the tune is spot on.[/QUOTE the size cam/ specs will play a big role if im understanding correctley ?
Old Sep 3, 2017 | 06:02 AM
hrdtail78's Avatar
hrdtail78
I'd suggest paying attention to corrected. My personnel touring bike is set up at 11.5 with a cam that closes at 60 and cranking still under 200.
Old Sep 3, 2017 | 08:19 AM
98hotrodfatboy's Avatar
98hotrodfatboy
200 ccp is doable but you better find a good tuner. They say there's a lot of good tuners out there but buyer beware.... A poor tune could lead to overheating and I've seen what overheating can do to a motor...... Take it right down..... 190 might be the right choice depending on where you live.... Or if you plan on touring.... You can't always get 93 octane.....
Old Sep 3, 2017 | 09:21 AM
Clayton24's Avatar
Clayton24
i under stand completeley thanks for all the info very helpful an educating in your guys opinion can i run the ccp alittle on the high side with the twin cooling keepin The temp down sum or should i still try to stick with 190 ?
Old Sep 3, 2017 | 09:39 AM
98hotrodfatboy
If you go with stage II or III heads you can push up the CCP. If no head work keep@190.....
Old Sep 3, 2017 | 09:46 AM
Clayton24's Avatar
Clayton24
ok i plan on doin heads too im also tryin to figure out a great cam i can use now an still use later with head work and maybe 107" i think the 103 twin cooled is advertised around 10.1 maybe if that helps ? Im learning a great deal from here thanks for the replies
Old Sep 3, 2017 | 10:07 AM
Clayton24's Avatar
Clayton24
would a 57h work on both accounts? Whats everyone take on this cam ?
Old Sep 3, 2017 | 10:18 AM
Clayton24's Avatar
Clayton24
or maybe woods tw777 ? Thanks for replies in advance i have sratched my head about this for weeks maybe a month ! Lol
