Stage 4?
Old Oct 8, 2017 | 03:04 PM
Vanderglide's Avatar
Vanderglide
6th Gear
Default Stage 4?
I’m a HD noob, this is my 1st Harley. The previous owner claimed it has a stage 4 big bore kit, from 88 to 95. How can I verify any of this without shop paperwork? ‘02 Electra Glide standard. Also can someone explain to me what exactly stage 4 entails?
Old Oct 8, 2017 | 07:36 PM
ntraindavefl's Avatar
ntraindavefl
A few Dyno pulls will verify.
Stage 4 should be cams, heads, throttle body. Pipe/AC as well
Old Oct 9, 2017 | 06:37 AM
target64's Avatar
target64
seeing where you live there are some race tracks close bye, you could check with them to see if they have a powerhouse or a Mr gasket cubic inch tester. and a whistler compression tester tool . it will determine the cubic inches and the compression ratio of the engine. without a tear down.
Old Oct 9, 2017 | 07:03 AM
ntraindavefl
Good point Todd. increased bore would be part of stage 4
Old Oct 9, 2017 | 07:23 AM
baloot-boy's Avatar
baloot-boy
Hope you bought it at a stage 1 price. He didn't have any paperwork or receipts from his build?
Old Oct 9, 2017 | 08:01 AM
Vanderglide
6th Gear
I don’t think I over paid, it was $5200. I didn’t realize what the stage 4 really was, so I didn’t give it much thought , or I would have asked him for some paperwork. It has screaming eagle heads & pipes that I can physically see.
The thing does run though. I bought it as a starter bike to see if it’s something I really wanted to do, and now I can’t stay off the damn thing. It has high miles 73,000, (12,000 on the build supposedly) so I was going to upgrade to something newer in the spring.
Old Oct 9, 2017 | 02:06 PM
bustert's Avatar
bustert
somewhere, there is a thread that allows you to determine bore by diagonal measurement through the plug hole piston down. he listed some measurements. could be on a diff forum that i read it maybe xlforum.
Old Oct 9, 2017 | 02:45 PM
QNman's Avatar
QNman
Screaming Eagle heads is a good sign...
Old Oct 10, 2017 | 05:30 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Couple pulls on a dyno would alert, as Dave has mentioned.
Scott
Old Oct 10, 2017 | 06:31 AM
EL in NH's Avatar
EL in NH
If he didn't do the work himself perhaps the shop that did remembers the bike and work performed.
