Actual difference in cam chests? 99-06 vs 07-
Old Nov 19, 2017 | 11:15 PM
Lundee's Avatar
Lundee
Default Actual difference in cam chests? 99-06 vs 07-
I found a freakishly cheap complete fueling cam chest kit. Chain drive not the conversion.
Only problem is, it's for the older and mines newer. Are the interchangeable? If not what's the difference? Any info would be great, thanks.
Old Nov 20, 2017 | 09:17 AM
FLASH1970's Avatar
FLASH1970
Cam bearing diameters are different if I remember right. Cant think of any other differences.
Old Nov 21, 2017 | 07:45 AM
nhrider1's Avatar
nhrider1
07 and up have hydraulic cam chain tensioners. They replaced the troublesome spring loaded tensioners used in earlier TC's.
Old Nov 21, 2017 | 08:12 PM
Max Headflow's Avatar
Max Headflow
By yours being newer, if it's 07 up, the cam won't work.. You might be able to have a machine shop bring the inner race up to 1 inch.
Old Nov 21, 2017 | 09:50 PM
bad tappets's Avatar
bad tappets
Inner cam bearings on 99-06 (99-05 on Dyna's) are .875". Inner cam bearings on '07 & up ('06 & up Dynas) are 1".
If its' an older kit, it will have the smaller inner journals and won't fit later model TC's.
Old Nov 22, 2017 | 11:35 AM
Lundee's Avatar
Lundee
Thanks gents. I'll keep on the hunt for the correct year.
Old Nov 23, 2017 | 06:56 AM
mstng5point0's Avatar
mstng5point0
Isnt this what conversion cams are for? Installing a new style cam plate into and older bike?
Old Nov 23, 2017 | 07:45 AM
Cobra1's Avatar
Cobra1
Yes but some parts like bearing bores are built into the engine case and can not be changed easily.
Old Nov 23, 2017 | 12:52 PM
bad tappets
Conversion cams have the .875 inner journal, and 1.00" outer; for using the newer style cam plate in older motors.
CtCruzer
Exhaust System Topics
Oct 15, 2011 11:30 AM
The Old Man
Jan 12, 2011 02:30 PM
roussfam
Dec 18, 2010 12:40 PM
electra glide
Engine Mechanical Topics
Dec 31, 2008 09:44 PM
IRready
Sep 10, 2008 07:49 AM
