95 Build Question
Old Jan 26, 2018 | 09:42 AM
papaduke187's Avatar
papaduke187
Default 95 Build Question
Have a question about compression with my 95 building a 2000 electraglide
Heres my build specs:
95 SE flat tops
96 heads,
andrews 37 cams
I am going to have the heads worked a little and decked for compression with an 030 hg.
I’m wondering what is a good target compression to hit with these on a 95 build. I’ve seen everything up to 10.2. I’m thinking about getting my heads decked to about 81cc’s to target about 9.8. Thoughts? Concerns I should have? Input would be much appreciated.
Old Jan 26, 2018 | 10:15 AM
Max Headflow's Avatar
Max Headflow
Get a DTT ignition.
Old Jan 26, 2018 | 11:22 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If your doing the heads then I would bring the comp to 10.0-10.2 and go with the Andrews 54 cams. A little more bang for the buck....
Old Jan 26, 2018 | 12:42 PM
papaduke187
Get a DTT ignition.
Max- I have a module already. Thank you!
I already have the cams..... but interesting idea.
Old Jan 26, 2018 | 01:15 PM
djl's Avatar
djl
95 SE flat tops
96 heads,
andrews 37 cams
I am going to have the heads worked a little and decked for compression with an 030 hg. I’m wondering what is a good target compression to hit with these on a 95 build. I’ve seen everything up to 10.2. I’m thinking about getting my heads decked to about 81cc’s to target about 9.8. Thoughts? Concerns I should have? Input would be much appreciated.
If the "worked a little" heads don't include larger intake/exhaust valves and port work, no need for cams with higher lift than the 37s. I would not set static CR below 9.8 and would consider 10:1. Measure deck height and, if you haven't done so, include that in you compression calculations or have the cylinders machined for zero deck. If larger valves are part of the head work, open up the intake valve reliefs in the piston to accommodate the larger diameter valve. Assume the motor is carbed so a programmable ignition will be important to the tune to avoid detonation. I would get it on a dyno ASAP and tune.
Old Jan 26, 2018 | 01:24 PM
papaduke187
I am going machine it for zero deck height. Running this setup on a couple of different calls (big boyz and hammer) milling the heads to 79cc should get me to 9.95-10:1The cylinders are currently at the machine shop getting bored out. I’m hoping I can get those picked up tonight so I can get the deck height measured this weekend. Once I get my heads finished I’m going to start with the head setup.... measuring piston to valve clearance etc. I’m not going with larger ports and valves I’m trying to keep this as steetable as possibly as I ride everywhere. Yes the bike is carb’d it’s got a mikuni 42 on it.
Old Jan 27, 2018 | 05:42 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Just sent a 98"/37/our Stage II Heads, back to Ohio, yesterday.
10.0 cr, V&H exhaust, ported t/body.
Tuned with Techno Research.
106 hp/112 ft/lbs, sae.
109/115, std.
Scott
Old Jan 27, 2018 | 05:11 PM
djl's Avatar
djl
Each to his own but larger intake and exhaust valves have no impact on "streetable" habits of these vtwins. Your call but it makes no sense to me to install stock heads back on a performance motor; the heads on Harley vtwin are where the major power gains can be realized. If you are OK with 10:1 compression as "streetable" and it is, you shouldn't be concerned that larger valves will negatively impact streetability.
Old Jan 27, 2018 | 08:06 PM
Max Headflow
IMO they can but with a 37 as the cam and a cr of 10 to 1, they would help.. Longer cams cam potentially suffer on the low end.. Still I like to keep the ports / valves small / efficient and run a longer cam at higher compression in a 95.
guesscrazy
Engine Mechanical Topics
Jul 8, 2016 05:29 AM
Booxr
15
May 2, 2016 09:00 PM
KingCripps
Aug 1, 2011 10:19 PM
Garcou
Jan 5, 2011 11:43 PM
cmashark
Sep 20, 2009 09:56 AM
