Cca
Old Feb 24, 2018 | 07:10 PM
Big Dave's Avatar
Big Dave
Default Cca
Going from a stk 09 96" to new 48 cams - should i be expecting more load as the bike cranks slow now
Time to take the battery out for a load test or is this to be expected ?
Thanks
Dave
Old Feb 25, 2018 | 07:30 AM
98hotrodfatboy's Avatar
98hotrodfatboy
No... battery time. how old is the battery?
Old Feb 25, 2018 | 09:06 AM
Big Dave's Avatar
Big Dave
I've had the bike for 2 years so battery age is unknown I'll take it out ahd get it load tested today
Dave
Old Feb 25, 2018 | 09:25 AM
98hotrodfatboy
Agreed.....
Old Feb 25, 2018 | 02:00 PM
djl's Avatar
djl
If the OPs battery needs replacing, a lithium replacement would be a good idea. Just replaced the battery in my '02 FLHT with lithium and should have done it last time. Shaved about 20 pounds off the weight and it spins, starts faster. A little more money but worth it.
Old Feb 25, 2018 | 06:26 PM
Big Dave's Avatar
Big Dave
Good news Bad news kinda thing
Battery tested good held 400cca for 10 sec and never fell below 12.5 volts
So now i have to find why it cranks so slow
Stk 09 96in with the 48 cams
Will check and see if its a tune issue or me issue - i know everything was lined up in the cam chest but if i have to ill open it up again
Hope eveyone is having a good day LOL
Dave
Old Feb 25, 2018 | 08:08 PM
98hotrodfatboy
I would check for a voltage dropped at the starter terminal. A poor or corroded cable from battery could drop enough to cause the same... Did it ever start since the cam swap?
As you stated earlier, Did you check the cams yet? I guess it's possible to retard the cam timing which will cause the intake valve to close sooner creating a little more ccp but I've never heard of anyone doing that before and am not even sure if it would start...
Old Feb 25, 2018 | 08:38 PM
Big Dave's Avatar
Big Dave
It actually starts and runs fine just a slow crank , ive second guess myself a dozen times and the cam timing and dots on the gears all line up ,i will be going into the wiring over the next week - If anything im thinking a bad ground someware
Its interesting for sure
Thanks
Dave
Old Feb 26, 2018 | 01:49 AM
2009blackpearle's Avatar
2009blackpearle
Default compression check
I would still do a compression check usually gives u a pretty good indication if cams are not lined up ive done about 4 cams over the years , as long as the rings are seating good on both cylinders u should be pretty close on the readings in both cylinders.
Old Feb 26, 2018 | 02:03 AM
rhuff's Avatar
rhuff
What did you end up going with brand-wise?
