Fxdls cams question
Old Apr 13, 2018 | 04:46 AM
DynaGuy22's Avatar
DynaGuy22
5th Gear
Default Fxdls cams question
hello all,
New to the form and just recently bought a brand new left over 2017 fxdls this past fall . Currently all that has been done to it performence wise is a stage 1 kit ( 2 -1 Bassani road rage 2 ,a powervision tune , and the heavy breather kit that comes on it .My question is what kind of cams can I upgrade to without doing any gasket changes or changes to the heads or pistons I.e. compression changes .From what I am seeing these bikes with the 110 will put down some where between 90-95 hp and around 115 ft lbs with my current setup tuned. I would like to see a little over 100 hp and 120ft lbs + ? I know there are 9 million + topics on this already where people ramble on about how great the 117 kit is and compression changes, heads etc ..but I just do not have that kind of money . I want cams that can Be installed into a stock motor and give me the aforementioned numbers with a nice lope . Would like to put cams in before I dyno tune.
Thank you all.
Old Apr 13, 2018 | 07:39 AM
cdonis's Avatar
cdonis
Look at the cyclerama 570-2. Not saying you'll get the numbers you want. There are more important factors when picking a cam than the max number on a dyno sheet.
Old Apr 13, 2018 | 08:28 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Good suggestion.
A Wood 5-6 is a contender as well.
Scott
Old Apr 14, 2018 | 08:40 AM
hrdtail78's Avatar
hrdtail78
With having a lighter Dyna. I'll throw the rocket 574 cam in the mix. If you do decide to add headwork in later. This cam will grow with the upgrades nicely.
DynaGuy22
General Topics/Tech Tips
Aug 18, 2018 03:01 AM
Rich67
Oct 27, 2011 07:00 PM
103 st bob
Exhaust System Topics
Sep 28, 2010 10:43 AM
denrock1676
May 13, 2010 08:49 AM
Philly76
16
Oct 22, 2009 12:59 PM
