engine dying at red light or stop sign
Old Apr 19, 2018 | 10:33 PM
cando's Avatar
cando
6th Gear
Default Stumbles
ON the M8's it's a sign the clutch safety switch is out, mine did the same thing with less than 500 miles on it. Stalled at a light and couldn't start till I put her in neutral. Try starting the bike in gear with the clutch in, it doesn't the switches bad and this is a very common issue with them.
Warning signs are stall's and erratic idle.
thanks for the information I'll pass it on to the dealership but they may not want to hear it as far starting my bike I've never been able to start it other than in neutral since I've had it
Old Apr 19, 2018 | 10:39 PM
TwiZted Biker's Avatar
TwiZted Biker
Don't let them bullshit you, it's a very well known issue some dealers will try and sandbag you as they will change the switch and have it go out again 20 miles down the road. Many threads in the M8 section in here on this very issue.
Old Apr 19, 2018 | 10:45 PM
perki48's Avatar
perki48
I would think it is a definite safety hazard to be required to have bike in neutral to start it................well at least since the kick start days.
Old Apr 20, 2018 | 05:55 AM
Campy Roadie's Avatar
Campy Roadie
Don't stall it on any train tracks
On a serious note, having a problem that causes a stall and no immediate restart sounds pretty darn recall worthy to me.
Old Apr 20, 2018 | 08:47 AM
103inches's Avatar
103inches
Old May 7, 2018 | 10:04 PM
cando's Avatar
cando
6th Gear
just to put a closer on this the dealership replaced the clutch safety switch and everything seems to be working now . thanks for all the feed back . have a different problem now. see post" WOBBLY FRONT END" THANKS.
Kawickrice
Milwaukee Eight (M8)
130
Sep 13, 2019 10:31 AM
rsmith0801
16
Nov 29, 2018 11:57 PM
skeeter86
32
Jul 10, 2018 07:09 AM
SupremeHD
May 5, 2018 08:55 PM
plutnicki
Jul 27, 2013 06:51 PM
