Revtech
Old May 7, 2018 | 02:42 PM
mrtom's Avatar
mrtom
Default Revtech
I have a 91 Softail with a 110 Revtech engine. I bought it that way. Rode it three times (fabulous) then parked it for the winter. Tried to start this spring. Would not turn past compression. Removed both plugs to check compression. 130 each. Replaced the front plug and it turns over no problem with rear plug out. It actually started like that. Replaced the rear plug and removed front plug. Starter won’t turn it past compression. Battery is new and strong. I installed a new stronger starter assuming it would solve the problem. NOPE. Same thing. With both plugs installed starter won’t turn it past compression. It moves the crank but not past compression. HELP!
Old May 8, 2018 | 12:10 AM
marcodarq's Avatar
marcodarq
it doesn't have little blue compression release buttons in the heads? most of those that i have seen came with them. little blue button that you push down before cranking the engine, usually right next to the spak plug, but could be in betweeen the pushtrod tubes too.
Old May 8, 2018 | 08:16 PM
Max Headflow's Avatar
Max Headflow
Needs a battery. Try jumping from a bigger battery to prove.
Old May 8, 2018 | 09:20 PM
mrtom's Avatar
mrtom
Default Solved the problem
Everything pointed to a bad starter. Got a brand new battery and same problem. Installed a brand new starter, big job, got it all back together and........same thing! Tried jumper cables from my truck battery. Same thing. Then I was thinking that maybe the NEW battery was defective and shorting out the truck jump. So I disconnected the new battery and jumped it again. BINGO! It turned over just fine. All this BS because of a defective battery. I confirmed it by putting a volt meter on the new battery and saw the voltage drop from 13.2v down to 5v when the starter is engaged.
No, it does not have compression releases. Compression is 130 each cylinder.
Old May 9, 2018 | 08:04 AM
Cofltrx124's Avatar
Cofltrx124
Just wondering what kind of battery so I can cross that one off my list?
Old May 9, 2018 | 01:20 PM
grbrown's Avatar
grbrown
Wink
Whoa there! A new battery isn't guaranteed to be fully charged, no matter what it says on the packaging. Before installing a new battery, especially on a big motor like mrtom's, it should be fully charged off the bike. His problems could be as simple as that - trying to start with a part-charged new battery.
Old May 10, 2018 | 10:53 AM
Cofltrx124's Avatar
Cofltrx124
Thanks for that info grbrown now I know why we have the charging system on the rack of napa batteries at the garage. Who would have known.
Old May 10, 2018 | 11:58 AM
grbrown's Avatar
grbrown
Thumbs up
Thanks for confirming that!
user 6485939
May 26, 2018 01:52 PM
BigBoreNighttrain
Dec 14, 2016 04:05 PM
cool-rider
Welcome Area Only
26
Mar 19, 2012 10:01 AM
1986FXST
EVO
Aug 24, 2008 08:50 AM
djprey
General Topics/Tech Tips
Jun 21, 2007 06:22 PM
