High idle question
Old May 12, 2018 | 09:13 PM
jmprewett's Avatar
jmprewett
5th Gear
Default High idle question
So got a question after a good day long ride and the old girl running great all day i was getting pretty twisty with the throttle the last couple miles home when i got home she was idling pretty high hook up the pc to the power commander and it says that the throttle is resting at 45% nothing seems stuck and works as it should was wondering if anyone else has had this issue only thought i had was that maybe i broke the throttle positioning sensor but im no mechanic oh and its a 2003 road king classic efi thanks in advance
Old May 13, 2018 | 05:00 AM
Misiak's Avatar
Misiak
Check for air leaks. My friend had air leak in throttle body area on his RK. The same symptomps.
Old May 13, 2018 | 09:37 AM
jmprewett's Avatar
jmprewett
5th Gear
Would the power commander show that the throttle is resting at 47%
Old May 13, 2018 | 10:58 AM
jbarr1's Avatar
jbarr1
Check for broken throttle shaft in throttle body throat,
PeelyP62
Electrical/Lighting/Alarm
Aug 18, 2017 03:06 PM
2K1FLHPI
Oct 29, 2016 10:21 AM
uklauren
Jul 19, 2013 09:33 PM
Bachus
Jul 6, 2011 10:18 PM
Chief101
May 24, 2007 07:20 AM
