noise on rear cylinder after 107 top end install...
Old Aug 30, 2018 | 06:20 PM
memphisharley's Avatar
memphisharley
ok..came home and raised pushrod covers on rear cylinder and I could spin intake pushrod with my fingers but not the exhaust.
I'm going to ensure the cam ​​​is on base circle and try adjusting them again on this cylinder. not sure why the exhaust lifted didn't bleed down. shouldn't it have?
thanks
Old Aug 30, 2018 | 09:24 PM
memphisharley
Originally Posted by djl
I am putting my money on a loose pushrod.
you were spot on..as usual. purring like a kitten now.
thanks to all for your replies as they were very helpful.
Old Sep 5, 2018 | 01:47 PM
djl's Avatar
djl
thanks
It did bleed down, you were either off the base circle or miscounted the number of turns for proper preload. Glad problem is solved.
Old Sep 7, 2018 | 05:54 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
How does the delivery feel now?
Scott
Old Sep 8, 2018 | 04:15 AM
memphisharley
Thumbs up
Scott
so far only 237 miles on her so still breaking her in. but man..let me tell you...twisting her from idle up to 3500 rpm is a blast. I can't wait to take her up through the rpms.
I will report back after I put 1000 miles on her but I couldn't be more pleased with your work and the outcome.
thanks again!
Old Sep 8, 2018 | 02:35 PM
94 ultra's Avatar
94 ultra
not to hijack but
I had a lot I mean ALOT of clatter on my 110 build today on initial start
SS Premium lifters and Screaming Eagle 24TPI pushrods
I had them set at 2.5 turns per Harley Instructions
SO I readjusted them to 3 turns -- .120
refired and 90 percent of rocker noise was gone
all over a half turn of the pushrod adjustment - its hard to believe
I still have a little tick like your video in my front but I only have 2 one minute heat cycles so far
I may add a couple flats to the front tomorrow
Thanks for the thread
Old Sep 8, 2018 | 02:46 PM
2009blackpearle's Avatar
2009blackpearle
most of the builders in here are saying .140 your almost there .140 is 3.5 turns on those se rods. I have set mine both 3 and 3.5 think the 3,5 is a bit quieter. gets better as the oil gets closer to 200 f 170 is where it seems to start getting quiet. and watch those lock nuts on those rods. I had a cpl crack think they are some funky light grade material. I took 5/16 nut to keep weight down and drilled out to 3/8-24 thread as locker
Old Sep 8, 2018 | 02:58 PM
94 ultra's Avatar
94 ultra
Yea I have heard
I may order a set of S&S quickies and swap them out
Old Sep 8, 2018 | 06:39 PM
94 ultra's Avatar
94 ultra
Check that
all my noise is coming from Air Cleaner
777 cams
I am good with 3 turns
Its hard to diagnose if your old
vittt000
EVO
Aug 12, 2012 02:21 PM
dan61t
Apr 24, 2012 07:24 PM
jlb0038
Exhaust System Topics
Jun 13, 2010 04:22 PM
48FLpan
Panhead
Apr 30, 2010 04:57 PM
tree88
Aug 6, 2008 11:46 PM
