Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hello I have a 99 Sportster 1200 case that I have got Wiseco 10 / 10 to 1 compression Dome top with Stage 2 thunderstorm heads right now I'm running a Andrews N8 cam I have the dynatek 2000i twin Tec single fire ignition Riviera Primo clutch this is my everyday Rider what do y'all think would be a good fit for that setup I can't find any kind of a or website that you can enter in what you have four components and come up with suitable parts thanks for your advice
the sport was a pretty hot setup from the factory and you have a tad more than it. when you build, you must have a purpose and design around it.
if you want to waken up what you have, install a johnson engineering sportgear. if you leave the final drive ratio it will pull like a banshie.
SE 536's seem to be pretty popular for a hot street build. Hammer's getting over 100hp with it in their finely tuned 1250 kit.
I went with Red Shift 630/585's for a table top torque curve in my 88ci build back a few years ago. 10:1 is MAX with the intake close on them stump pulling bumpsticks.
