Cam??
Old Mar 30, 2019 | 05:26 PM
HarleyBrutus's Avatar
HarleyBrutus
4th Gear
Default Cam??
How is everyone doing? I have 2008 ultra classic with 96 inch motor. I was told that cam tensioner needs to be replaced. I'm working with a super tight budget, but figure while down there i would like to have better cam with more power without having to do any other work. The only upgrades i have so far are an Arlen Ness stage 1 big sucker air cleaner and Rhinehart true duals with 4 inch mufflers. All suggestions welcome. Thanks.
Old Mar 30, 2019 | 09:05 PM
Big Dave's Avatar
Big Dave
Tried and true Andrews 48 , Best bang for the buck in a stock 96"
Dave
Old Apr 1, 2019 | 11:26 PM
dfwhockey17's Avatar
dfwhockey17
^That...or PM me, I have some take out SE255's I want to move!
Old Apr 2, 2019 | 07:33 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We are having great results lately with the S&S MR103, particularly if a .030" head gasket is introduced.
Just sent one home yesterday in a 107"/no headwork.......100 hp, 116 ft/lbs, sae, with almost flatline torque.
Scott
Old Apr 2, 2019 | 07:59 PM
cdonis's Avatar
cdonis
Scott
scott, rc cycle tuned mine, 103 all stock except mr103s, intake and d&d bobcat 98/111.👍 I liked that cam while I had it, slight dip but came on hard at 2800.
Old Apr 3, 2019 | 05:41 AM
Hillsidecycle.com
Sponsor
Nice.
We are going to build another 107" very soon with that cam, after conversation yesterday.
This time we are introducing our Stage II Heads.
Scott
Old Apr 3, 2019 | 06:22 AM
RANGER73's Avatar
RANGER73
You said your on a tight budget.
Unless you're doing the wrenching just do the tensioner.
Old Apr 3, 2019 | 07:04 AM
Mattbastard's Avatar
Mattbastard
Also, that engine is of the era where the cam chain tensioners are hydraulic as opposed to the older ones that were spring type and wore out quickly. What's the basis behind the recommendation? Have you personally experienced a bad hydraulic tensioner or is someone in your riding group suggesting it based on the spring tensioner issue?
And you say "cam chain tensioner", which one?
Old Apr 3, 2019 | 10:13 AM
djl's Avatar
djl
Inner cam bearing upgrade should be included the the scope of work for the cam chest work. The Andrews 48 is probably the best choice for a cam only upgrade in a touring model and not steering the OP away from the 48. However, if considering the MR-103, take a look at the Cyclerama 570-2 as well.
67rayson
Engine Mechanical Topics
11
Dec 7, 2015 10:57 AM
roaddr
Oct 20, 2012 08:00 PM
tomb105
Oct 16, 2012 03:41 AM
Tanker2
Exhaust System Topics
May 28, 2008 08:58 PM
mikeyflhti
Aug 29, 2006 10:22 PM
