New Noise
Old Apr 26, 2019 | 12:25 PM
rkoivisto's Avatar
rkoivisto
Default New Noise
I've got a new noise on my 2013 FLHTK. If I start it up cold and shut it back down within 30 seconds I hear a metallic clink from the area of the front head. It's pretty repeatable and I'm wondering if there is anything that could cause that noise and also cause oil consumption.
I'll also add that about a year ago I started hearing noise while the engine was cold running down the highway. I attributed it to the throttle body which had never made noise before that. Now I'm wondering if what I thought was the throttle body noise is related to the new noise. Does anyone know if temperature has any effect on throttle body noise?
I've got a trip planned for September and want to make sure I take care of any issues before then.
Any help would be appreciated.
Old Apr 26, 2019 | 04:37 PM
Max Headflow's Avatar
Max Headflow
My guess would be the compensator and you think it's coming from the head. You didn't say how many miles on the bike.
Old Apr 26, 2019 | 06:16 PM
rkoivisto's Avatar
rkoivisto
Thanks for reply, Max.
I don't think it's the comp. Sounds like it's more on the right side. 140,000 miles on it. I replaced the flywheels (S&S) and had the heads ported at 83,000 miles.
Tonight when I rode it home from work, I heard it again at shutdown. It's a warm day and was up to operating temperature, so I'll have to back up on saying it only happens when cold.
Randy
Old Apr 26, 2019 | 06:20 PM
Max Headflow
Maybe a bad cam chain tensioner?
Old Apr 26, 2019 | 06:48 PM
rkoivisto's Avatar
rkoivisto
That's a good thought.
You don't think it could be from the head? The only thing I could think of was a loose valve guide, but don't know if that makes sense.
Old Apr 27, 2019 | 12:39 AM
Max Headflow
I would think that if it were a valve guide or seat for that matter, it would make more noise when hot as a loose seat or guide will only become looser as everything heats up.
Old Apr 27, 2019 | 06:53 AM
rkoivisto's Avatar
rkoivisto
I slept on it last night and I think you have a good point. The cam pads make the most sense.
I think I'll just take a looksee in the cam chest.
Thanks for the help
Old Apr 27, 2019 | 08:16 AM
bustert's Avatar
bustert
a hydraulic lifter is another source. when cold and the engine was down for a while, spring pressure will devoid the lifter of oil and the hd lifters can take a good while to operate correctly.
Old Apr 27, 2019 | 10:30 PM
rkoivisto's Avatar
rkoivisto
I appreciate the input, but it is not a lifter. It's difficult to describe a noise, but if you heard it you would understand.
Old Apr 28, 2019 | 08:56 AM
Max Headflow
Anter thing to look at could be a loose pinion sprocket. If either that or chain tensioner, the noise would stem from how the motor stops when cool. The motor will stop quicker possibly leaving it in a position where lifter rolls past a the tops of a cam lobe and the valve spring pressure rotates the cam forward. The action either snaps the chain or rotates a loose sprocket and you get the click. It's a guess for sure but tensioners do fail and pinion sprockets come loose.
martin10
Sep 21, 2018 08:51 AM
troop8520
May 3, 2013 12:35 PM
97classic
EVO
Jul 14, 2009 02:17 PM
1peter
Jun 5, 2009 11:10 PM
RMBLON
May 17, 2008 04:23 AM
