Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Looking at specs for certain jap bikes raises an interesting question: why can jap bikes run almost 13:1 compression, while HD struggles with 9:1, with many of the newer HDs having even lower compression?
Take the Suzuki GSX-R600 for instance. A stock 2014 model had 12.9:1 compression with 103 bhp. HDs new super 117 inch boasts a whopping 80 horsepower. Ive ridden them. My 93 Shovelhead pulled harder.
Yes, I understand the difference between torque and horsepower: its the difference between a dragster and a Formula 1 racecar.
But my question is valid. How can the Suzuki squeeze 12.9:1, while HDs have to use much lower compression?
Jap is an English abbreviation of the word "Japanese". Today it is generally regarded as an ethnic slur among Japanese minority populations in other countries, although English-speaking countries differ in the degree to which they consider the term offensive.
a lot has to do with design
then there is engine management
rice usually has smaller cylinder displacement which is a plus. while over-all, the rice displacement mass maybe greater, it is spread out unlike hd which uses two larger sized pistons and larger displacements. the small cylinder by itself is less prone to detonation. if you look at the auto industry, the trend is using smaller displacement, direct injection and boosted intake charge. all of this makes detonation less of an issue and easier to control.
hd is still archaic.
then look at how the engines produce power, aka, long vs short stroke and power pulses per rpm for ex.
can a hd engine produce more compression numbers, sure but at a cost, they have issues with heat as it is and not cost worthy for a street machine. back in the day, a 500cc rice off the showroom floor would smoke anything that hd offered off the floor.
Also chamber design makes a big difference, Jap bikes are 4 valve per cylinder pent roof (very small valve angle, can run a nearly flat top piston and get high compression, Harleys are old style hemispherical with wide valve angle, and must use a high dome to get compression which messes with the flame front.
I've done a bit of research on this over the last few months. The quick answer is that liquid cooling, total ignition advance, combustion chamber design, piston crown design, and cam/injection timing all play a part in allowing the metric bikes to have much more radical CR than the Harley equivalents.
