cam install - TDC
Old Jul 11, 2019 | 02:35 PM
Fscott4's Avatar
Fscott4
Default cam install - TDC
I just installed SE 255 cams in my 08 flhtcu. My concern is TDC and getting this correct BEFORE I install the cone, pushrods, ect. My thinking is if the cam marks are in the correct position and the cam drive gear is correctly lined up with the crank gear mark then I can go ahead and finish it up. Im thinking it might be possible to put this together 180 degrees off and I dont want to do that (obviously).
I would appreciate some clarification on this before proceeding.
Thanks!
Old Jul 11, 2019 | 02:39 PM
strych9's Avatar
strych9
If the marks are aligned properly, you're good to go.
Old Jul 11, 2019 | 02:46 PM
Fscott4's Avatar
Fscott4
Thats what I figured, but I've figured wrong a few times before and I dont want to do this project twice!
Old Jul 15, 2019 | 01:11 AM
23Seven's Avatar
23Seven
That part is straight forward... The same doubt crossed my mind when I did my cams as well.
Wmitz
Engine Mechanical Topics
May 19, 2014 09:28 PM
jurgie
Mar 1, 2010 09:35 AM
bdasource
Apr 7, 2009 10:14 AM
t150vej
EVO
Dec 21, 2008 01:45 PM
HTRAUD
Dec 11, 2006 10:06 PM
