Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Just did a 107 build 10.25.1 compression head port and larger valves..600 lift springs stock throttle body 2016 street glide.Have cyclerama 570-2 cam in bike now.What would be a good cam with good trq.from low through out.Was looking at woods 777 or tman 580 or 590.Thought 's on a different cam.Thanks
It would help to know what's not to like about the 570-2; it should be a good fit at 10.2 static with off idle torque that carrys out on a flat curve providing instant torque across the power band.
Has the build been tuned? Do you have a chart? If so post it.
JMHO but I would not toss the 570-2 for any of the cams listed by the OP. Unless looking for less low rpm torqued and more mid to high horsepower.
It hasn't been tuned with this setup, i did have it tuned with this cam and 103 engine.It runs ok now but i just thought there was a better cam maybe not. Going to get it tuned if i changed cam.
Get it tuned now, guaranteed you are not getting the most out of the setup.
