Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
S&S Grand National's or MK45's, Jackpot Hi Roller or Outlaw's. Leave the secondary baffle inserts in place and that low RPM torque and response will increase significantly. If you were within driving distance I would test mufflers back to back for no charge for those watching to see.
