‘06 vs ‘99 TC Heads
Old Jan 5, 2020 | 10:57 AM
txphatboy's Avatar
txphatboy
Default ‘06 vs ‘99 TC Heads
Thinking of upgrading heads from current mild street port to better flowing Stage 2 or better heads. Will probably sell current heads locally, so looking for a set of take-off heads to have ported. Is there any difference between early and later TC heads? Can a ‘14 touring head be used on ‘PO softail? I thought They were all interchangeable, but remembered reading somewhere that newer heads had different intake setup where TB manifold mounts. Will ‘01 TB manifold fit the newer heads?
I am also thinking about getting a slightly bigger TB, but cost of HPI models are a little steep. Was looking at some 50 mm SE TB’s, but not sure if sensors from 2001 softail will be compatible with the TB’s listed for ‘06 and later TC. Other than TBW models, are TB’s compatible with all cable TC’s?
Thanks for all help.
Old Jan 5, 2020 | 11:19 AM
djl's Avatar
djl
Originally Posted by txphatboy
Thinking of upgrading heads from current mild street port to better flowing Stage 2 or better heads. Will probably sell current heads locally, so looking for a set of take-off heads to have ported. Is there any difference between early and later TC heads? I thought either could be used, remembered reading somewhere that newer heads had different intake setup where TB manifold mounts.
i am also thinking about getting a slightly bigger TB, but cost of HPI models are a little steep. Was looking at some 50 mm SE TB’s, but not sure if sensors from 2001 softail will be compatible with the TB’s listed for ‘06 and later TC. Other than TBW models, are TB’s compatible with all cable TC’s?
So, I assume you have a '01 softail?
Anyway, jif you are going to have the heads ported, it doesn't matter whether they are early or later unless you prefer the 7mm valves and the beehive springs. If that is your preference, you will need '05 or later heads. If you use '06 up heads you will need intake flanges.
The sensors for the later T/Bs are different but Zippers offers a conversion kit to make them compatible. Have you considered having your T/B bored? About half the price of an HPI piece. IIRC, the '01 T/B is 44mm and a two piece unit but can only be bored to 46mm, not sure if that is going to be a big enough step for you. The SE 50mm T/B (27623-05A is actually not a bad piece of hardware, cable operated and not a bad deal for about $350. You will need the sensor conversion kit from Zippers and a proper crimping tool and a different air cleaner. Also have the intake ports matched to the T/B and I suppose a new intake manifold.
Old Jan 5, 2020 | 02:08 PM
txphatboy's Avatar
txphatboy
Yessir - 2001 Fatboy. My 44mm TB was bored to 48 by Dan Vance years ago, but I have had several head porters tell me to get a bigger TB. Not sure what the 48 flows? Vance also did some epoxy work to increase velocity.
I think the SE 50mm TB is a single piece that includes manifold, but not sure. I may hold off at this point - sounds like more involved than I was hoping for. You mentioned needing a new air intake backing plate. I have never noticed any of the air intakes specific to different year model TC’s
Old Jan 5, 2020 | 04:49 PM
djl's Avatar
djl
Your are right, brain fart here; all the later T/Bs are one piece. The air cleaner backing plates are sized to the T/B and I am not sure if the '01 backing plate will mate up to a 50mm T/B. I do know that it will not mate up to a 58mm TB. I don't see any advantage in going from a 48mm to a 50mm T/B and doubt the change would register on the butt dyno. Don't know what cams or compression you are running but a cam change and/or more compression might be a better way to spend the $$.
Old Jan 6, 2020 | 06:05 AM
Campy Roadie's Avatar
Campy Roadie
There's some very good info about TC heads in this PDF
Old Jan 6, 2020 | 06:32 AM
prodrag1320's Avatar
prodrag1320
for our street port heads,we prefer the later,7mm stuff.if doing stage II headwork,it really dosnt matter (even on stage II earley heads we like to use 7mm guides,valves & springs)
Old Jan 9, 2020 | 04:36 PM
Ed Ramberger's Avatar
Ed Ramberger
If this was a 2001 TB, it was 40mm not 44. People mistakenly measured it at the air cleaner surface, not the bore/butterfly. A 2001 cannot be bored to 48mm at the butterfly.
If it was a 2006 or later one piece, it was a 46mm bore at the butterfly, and the SE was 50mm.
Old Jan 9, 2020 | 06:26 PM
txphatboy's Avatar
txphatboy
One last thought here - thinking of finding a used HD 46mm throttle body and bore 50mm and matching ports. Are the 43 and 46mm TB’s interchangeable as far as all sensors, injectors, etc? I already have higher flow matched injectors from Marren, but want to make sure I can use them and all sensors, of if any adapters are needed.
Old Jan 9, 2020 | 08:14 PM
djl's Avatar
djl
No, later T/Bs have different sensors but Zippers sells a "conversion" kit to upgrade the early T/B to be compatible with later T/B sensors. You will also require the proper crimping tool.
Old Jan 9, 2020 | 08:25 PM
txphatboy's Avatar
txphatboy
Thanks DJL. I know you had said this was the case for SE TB’s, but I was hoping the 43 and 46 used same parts.
