FXDB Hillside 117”
Old Feb 29, 2020 | 09:07 PM
AdamM's Avatar
AdamM
Quick update: So after discovering that the connecting rods were trashed, ordering a new set of S&S replacements and then FedEx losing the box they were in for four days, the crank work & case boring should finally be wrapped up this week. I spoke with Scott Friday morning and it sounds like my Hillside goodies will be headed my direction early this coming week. Once everything’s here the assembly can begin!
Little by little this ended up being more than just an engine build and turned into a “you’re in this far what’s a little more”. So along with the engine, we’ve got a chain drive conversion, radial brake caliper conversion front and rear, Galfer full floating rotors, ARP bolts for just about every hole in the bike, and swapping out the Works Performance for a set of Öhlins HD 764s. Hoping to have the rest of the bike perform as well as the engine should 😂
With the finish line finally in sight, I’ll have more updates and photos to share
Old Mar 10, 2020 | 09:30 AM
Big_O's Avatar
Big_O
Do you plan on keeping the Thunderheader or you going to a bigger pipe?
Old Mar 10, 2020 | 09:31 PM
AdamM's Avatar
AdamM
Im planning on changing the exhaust. I haven’t decided which one though
Old Mar 11, 2020 | 07:21 AM
harley#1's Avatar
harley#1
try not to druel when you smile. lucky s* it.
Z
Engine Mechanical Topics
31
Jul 30, 2021 06:40 PM
brad75raiders
May 2, 2017 04:19 PM
slvrscoobie
Jan 26, 2017 07:30 PM
128auto
Mar 31, 2014 04:56 PM
junker73hd
Shovelhead
34
Nov 18, 2010 12:54 PM
