Motor to far back
Old Jan 23, 2020 | 05:29 PM
Kirkster's Avatar
Kirkster
Default Motor to far back
I was wondering if anyone has ever had this problem? My motor is sitting to far back and the rear rocker cover is up against the frame. I loosened up the front mount put a strap around the motor and pulled it forward started it to let it settle in tightened everything up still having the same problem.
Any help would be greatly appreciated
Old Jan 23, 2020 | 05:57 PM
GearheadMike's Avatar
GearheadMike
Looks like a custom bike problem. Someone put a motor in a frame it was not designed for. No simple fix! Is there enough room on the frame mounts to oval out the holes and slide it forward?
Old Jan 23, 2020 | 06:45 PM
djl's Avatar
djl
Always helps to know the make, model and year.
Old Jan 23, 2020 | 06:54 PM
RDHIGH's Avatar
RDHIGH
Did you do some motor work ? Stroker? May be too tall...
Old Jan 23, 2020 | 10:12 PM
Mattbastard's Avatar
Mattbastard
That or the cleve blocks in the swingarm are really gone to **** along with the front motor mount.
Old Jan 23, 2020 | 10:44 PM
Max Headflow's Avatar
Max Headflow
Dyna, Bagger/FXR or softail?
Old Jan 24, 2020 | 09:53 AM
Campy Roadie's Avatar
Campy Roadie
Sawzall
Old Jan 24, 2020 | 01:57 PM
98hotrodfatboy's Avatar
98hotrodfatboy
https://images.app.goo.gl/LbBe4A8ZTS7beCTb7
Old Jan 24, 2020 | 02:04 PM
Kirkster's Avatar
Kirkster
It's a 1985 FXRT frame with a late style Evo 80" (1340).
Old Jan 24, 2020 | 02:07 PM
Kirkster's Avatar
Kirkster
No took one out that had some problems and put this rebuilt one back in. Just stock
