Motor to far back
Old Jan 24, 2020 | 02:29 PM
Tom84FXST's Avatar
Tom84FXST
You should have a 1/2" clearance in that spot...you have something that mounts the motor upside down or backwards...post pics of all the mounting points...including how the trans mounts to the motor...
Old Jan 24, 2020 | 02:50 PM
RDHIGH's Avatar
RDHIGH
Old Jan 24, 2020 | 09:05 PM
Mattbastard's Avatar
Mattbastard
Do you have the swingarm/transmission connection bolted firmly and correctly onto the frame?
Old Jan 24, 2020 | 09:12 PM
Kirkster's Avatar
Kirkster
Yes it's all tight
Old Jan 25, 2020 | 03:39 AM
joe40x's Avatar
joe40x
Does the inner primary line up?
Old Jan 25, 2020 | 09:12 AM
Kirkster's Avatar
Kirkster
Everything lined up good. Bolted up nice and no leaks.
Old Jan 29, 2020 | 03:51 PM
Kirkster's Avatar
Kirkster
Thanks for everyone's help
I ended up slotting the mount bracket higher and that did it.
Thanks
Old Jan 29, 2020 | 04:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You didn`t fix the problem, you just took a short cut...
Old Jan 29, 2020 | 04:34 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Agreed..
So OP, you altered the position of the motor and did it change anything with the alignment from motor to trans via the primary.. ?
death trap
Exhaust System Topics
20
Mar 19, 2014 05:00 AM
1955RigidFrame
Custom Models
Mar 20, 2013 08:00 PM
TO34
Oct 22, 2012 06:58 PM
mhuff
Dec 31, 2010 05:03 AM
eljefe
General Topics/Tech Tips
Jan 31, 2008 09:36 PM
