Stock cam alignment issue
Old Mar 21, 2020 | 10:54 AM
Clint case's Avatar
Clint case
2nd Gear
Tore down the bottom end again just to double check the crank and bearings. Everything is fine. Flywheel is centered and spins freely. No run out on the main shaft. Seems perfect. I think what might have happened is that I had my flywheel rebuilt a couple years ago due to the counterbalance timing gear spinning out of alignment. I guess its possible that when it was rebuilt the tolerances probably were shifted a little and I might not have checked the cam gear alignment when I first rebuilt it a couple years ago. Now I noticed it on this rebuild and I thought something was wrong. I'm ordering the spacer kit and hopefully my theory about the flywheel is why the tolerance has changed. Thanks for the help guys.
Old Mar 21, 2020 | 01:45 PM
marcodarq's Avatar
marcodarq
Ed mentioned an important point. The instructions say to push in and pull out on the cam sprocket while measuring for the correct spacer/shim. i'd re-check that part myself.
m
Old Mar 21, 2020 | 02:00 PM
Max Headflow's Avatar
Max Headflow
m
Kinda what I was saying in #6.
Clint case
Twin Cam Motors
Mar 14, 2020 07:45 PM
Clint case
General Topics/Tech Tips
Mar 14, 2020 01:54 PM
GJSchultz
Jun 9, 2016 02:46 PM
Kaycee
Exhaust System Topics
Jul 8, 2013 07:02 PM
micalaut
Apr 9, 2013 05:57 PM
