Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Totally agree that the OP needs to find a new tuner first and get a proper tune first. A good tuner can sort the tune out and will also be able to tell if the clutch is slipping during the tune.
If clutch slip remains to be suspect the OP has a couple of options. OEM clutch pressure spring is 280# for '06 and later models; '99-'05 spring is 320#. Don't know the OPs model year but if running the 280# spring, no way will it hold that power; maybe the earlier 320# spring will but maybe not at peak. Cheapest way to check clutch action would be to install the SE "heavy duty" green spring; at 380# and see if it makes a difference. If it does, the AIM VPC clutch hat with the SE 380# spring would be a good combination with decent lever pull as the heavy spring holds lower rpms and the hat acts as a lock up as the rpms increase. At $295, it ain't cheap but won't break the bank.
I completely agree with all the advice given at this point, Diagnose the problem before you start throwing parts at it. The best way to do that is get it back on the dyno with a competent operator
OP your location says Indiana. You are probably not far from one of the best tuners in the country who resides in Evansville, I live in central Ohio and take my bikes to him
I'm in Indianapolis.. wouldn't be opposed to taking it down there.. what's the name of the shop or guy I should contact down there.. I'll give him a call.. thanks everyone for your input and knowledge.. the clutch definitely needs beefed up.. so I'm still planning on upgrading it before I have it tuned again..
I've heard of them. it's about 3.5 hrs from me.. I know Jamie at fuel Moto is really good at tuning.. And could throw on one of those variable pressure hats.. I heard might be a discount for forum members.. Any truth to that? I actually got my boarzilla from them.. and they've done some heads for me before but never been up there.. if this Corona virus stuff would pass was thinking about making the trip up to see them and check out the Harley museum up there.. is it Darren over in Evansville?
It’s either a bad tune or slippage. Either way, you can’t go wrong with a VPC. It looks like you’ve got all of the other bases covered. That engine is laying down some power!
Its either a bad tune or slippage. Either way, you cant go wrong with a VPC. It looks like youve got all of the other bases covered. That engine is laying down some power!
