Torque dip .. suggestions?
Old Apr 13, 2020 | 12:21 PM
  #41
Bafflingbs's Avatar
Bafflingbs
Originally Posted by memphisharley
yep...and as max stated..try shifting while twisting the R's in the upper rpm range as this has been my experience.
I’ve never had an issue shifting, not even at over 5,500 rpm’s. I don’t doubt you, I’ve just never experienced any difficulties shifting with my VPC.
Old Apr 13, 2020 | 12:30 PM
  #42
Indyrider35's Avatar
Indyrider35
Thanks guys for the info.. even when I'm getting on it I very rarely shift past 5000 I normally shift way earlier just cruising .. so hoping that won't be an issue..
Old Apr 13, 2020 | 12:56 PM
  #43
Max Headflow's Avatar
Max Headflow
The persons that don't have this issue, are generally using the VPC that clamps less. Still the initial pull will be harder than stock inthe upper RPM range. The VPC adds pressure to the pressure plate which ends up being at the lever when the clutch is pulled in.
Old Apr 13, 2020 | 04:47 PM
  #44
ntraindavefl's Avatar
ntraindavefl
Have a few vpc hats of the highest pressure. Never noticed a harder pull at high rpms. Guess I’m having too much fun to notice or maybe because my arms are jacked. True statements......but I’ll check the mirror again just to be sure
Old Apr 13, 2020 | 09:10 PM
  #45
Max Headflow
Do that and put a tach on your bike. I ran a VP92 for about 300 miles and it sucked.
Old Apr 14, 2020 | 12:38 PM
  #46
RKGDCG03's Avatar
RKGDCG03
Veteran: Coast Guard
If you are in the Indianapolis area try calling Horsepower Inc. They also do tuning. I don't know of anybody that has used them as I am the Left coast but might be worth a phone call.
Old Apr 14, 2020 | 03:19 PM
  #47
ntraindavefl
They all do
Old Apr 15, 2020 | 11:46 AM
  #48
Sambo62's Avatar
Sambo62
+1 on Daren down in Evansville...
Old Apr 15, 2020 | 12:57 PM
  #49
Indyrider35
I've spoken with Jimmy over there great guy
Old Apr 15, 2020 | 05:29 PM
  #50
djl's Avatar
djl
Running the AIM VPC on a 98" (115/115) and have had some issues when power shifting; not so much with the pull but rough engagement. Pingel electric shifter solved that problem. I only use it when the occasion calls for it and have no issue with pull or engagement with normal shifting.
mkguitar
Apr 7, 2020 08:00 PM
tonymacomb@yahoo.com
May 3, 2008 09:09 PM
dirtpan
Exhaust System Topics
Sep 30, 2007 09:11 PM
Vector
Aug 10, 2007 03:14 PM
DenimStreet
Apr 1, 2007 07:00 PM
