Gear Drive
Old May 5, 2020 | 08:08 AM
Tarkus60's Avatar
Tarkus60
Default Gear Drive
So I purchased my 2002 RK a few years ago it had 16k on her. She now has 36k.
So right after I purchased the bike, I removed the cam cover to check my tensioners and to my surprise was a gear drive.
I then connected my laptop to the pc3 and it listed Andrews 37G cams.
So my question is what is the life span of a gear drive setup?
And the lifters?
I am also assuming the inner cam bearings were replaced. All I know about the bike is it cam from Sandy's HD in Michigan.
Old May 5, 2020 | 08:17 AM
eighteight's Avatar
eighteight
IMO
The gear drive will run as long as your engine. ( this assumes the crank remains true, chances are good on an `02)
Lifters = 50K miles
Don`t worry, ride it.
Old May 5, 2020 | 10:24 AM
jbarr1's Avatar
jbarr1
I wouldn’t count on 50k for the lifters. Many change them at 25k as good preventative maintenance.
Old May 6, 2020 | 05:25 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The T/C lifter(roller) isn't as prone to premature failures like their Evo c/parts that would fail, unless subjected to over-the-top valve spring pressures.
If the hydraulic unit begins to fail, you'll hear monentary valvetrain noise upon start-up, and usually then, from the f/exhaust.
Scott
Old May 7, 2020 | 05:28 AM
prodrag1320's Avatar
prodrag1320
gear drives will more or less never need replacing (like said earlier,as long as run out dosnt move over spec),i would replace lifters with some good aftermarket units
Old May 7, 2020 | 07:35 AM
Danishbanker's Avatar
Danishbanker
Scott
Scott - What and where does the noice come frome ?? ( f/exhaust ) ... is the noice only there if the lifters are bad ?
Thanks
Claus
cvaria
Apr 14, 2016 11:54 AM
fergerburger
Shovelhead
16
Sep 3, 2015 12:38 AM
Rednosedherring
Apr 26, 2014 10:06 AM
anubisss
Dec 13, 2007 08:59 PM
riden2low
EVO
Apr 13, 2007 02:23 AM
