110 cylinder swap question
Old Jun 12, 2020 | 11:02 PM
Rob Misener's Avatar
Rob Misener
Stage I
Default 110 cylinder swap question
There are 110 cylinders and pistons for sale where i live and they came off of a 2016 Low Rider S, I have a 2014 Street glide special, Will they work on my bike?
Old Jun 13, 2020 | 12:27 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Nope! They're not a "bolt on" part. You'd need some case work to allow them to fit.
Old Jun 13, 2020 | 06:13 AM
prodrag1320's Avatar
prodrag1320
cases will need to be bored
Old Jun 13, 2020 | 06:20 PM
flanigans45's Avatar
flanigans45
Well if the bike is a Dyna low rider S? the factory motor is a 103 cid. If it has 110 cid clys. Thay would be the new slip in clys. Thay could be PRO 4" big bore Blot - on clys. Part # 92500039. If so thay will fit. that will make a 110.
Old Jun 13, 2020 | 07:18 PM
OldEnuf2NoBtr
Nope. The cases would have to be bored! They are not a direct bolt-on.
Old Jun 22, 2020 | 01:57 PM
twincam10353's Avatar
twincam10353
Following this....S&S sells a 110" kit for the 103" that requires no boring or case modifications...
Old Jun 22, 2020 | 10:04 PM
memphisharley's Avatar
memphisharley
reread the op. the op is not asking about the 110 "drop on kit".
Old Jun 23, 2020 | 09:46 AM
twincam10353
Gotcha, my bad.
ketch
Engine Mechanical Topics
Oct 21, 2019 07:57 AM
Dirt Farmer
Jan 15, 2015 03:44 PM
C.J
Sep 30, 2014 02:41 PM
Jmbeebe0722
Sep 4, 2013 11:34 PM
1sweetglide08
Jan 2, 2013 11:21 PM
