2004 Sportster Engine Problems
I tried to post this yesterday but I am not sure what happened. I don't see pending posts anywhere so I am trying again.This is my first post on the forum.
I may finally be upgrading to my first Harley!
I actively scan craigslist for good deals on bikes and have been looking for a good deal on a Harley. I came across a local add from a guy selling a 2004 Harley Davidson Sportster 883 that was "converted to 1200 with Buell cylinders". He has it listed at $2000 because it "needs engine work".
Now, I have experience ripping apart old Honda CB motors.I have taken apart a CB650 engine and crankcase so I have some experience working with motorcycle engines but I know Harley's are a different beast.
I talked to him a little bit about what he thinks is wrong with it. He says that however long ago he started to hear a knock in the engine and then it simply stopped cranking over. I asked him if it is seized and he said "probably". Since he said "probably" I am at least assuming that it didn't seize while it was running otherwise it would have been a solid "yes".
He says it could be something with a push rod? Looking into how push rods work in Harley engines I cant imagine that could cause an engine not to crank over. He says he is not mechanically inclined but he is 95% sure it is in the top end.
I was able to talk him down to $1000 for the bike after telling him how it has been my dream to own a Harley and how I need to be prepared for unexpected cost while repairing the engine.
Here is a picture of the bike:
And here is the original ad text:
"Titled as an 883 it was converted to 1200 with Buell cylinders. It needs $500-1500 (work depending on who does it). 19,3435 miles (15k on the cylinders). 1500 miles on the tires. Garage kept no leaks. I’d keep it and have it repaired except my friend and mechanic passed away. It’s worth more in parts.
Includes:
1. Twintec electronic Ignition module
2. Supertrap Exhaust
3. Windshield
4. 2up seat
5. Backrest
6. Luggage Rack"
What do you guys think? Is it worth it to take the risk on the repair? I know that I pretty much have to be willing to "burn" $1000 if the engine is totaled.
Is this "converted to 1200 with Buell cylinders" something to be concerned about? Is converting the engine to this something that causes catastrophic engine failures?
What kinda of cost should I expect for special tools needed to rip apart a Harley motors top end?
I am excited to hear from the people on this forum. After finding this forum and reading around a bit, I feel like I am becoming apart of an awesome community. If I do get the bike, I plan on starting a thread so I can ask for help in diagnosing the problem and document the repairs with your guys insight.
Thank you for your time, consideration, and wisdom.
Bring it home take it apart and learn something
Get with Hammer Performance once you figure out what's wrong and what direction you want to go.
Most importantly, order a Service Manual, from Harley, today. Aftermarket manuals are no comparison to the factory manuals, in particular when you're going this deep.
