Crankcase venting
Old Jul 27, 2020 | 12:14 PM
twincam10353's Avatar
twincam10353
Default Crankcase venting
Looking at Feuling's vented dipstick for my 16 FLHXS. If I went this route, would it eliminate the need of an external breather system for my air cleaner? Or would you run both systems together?
Old Jul 27, 2020 | 05:15 PM
60Gunner's Avatar
60Gunner
I wouldn't vent out the dipstick or any lines running out of the oil tank. I also wouldn't vent out of 2 different locations.
IMO, the best place to vent is the cam chest. As it is, crankcase pressure travels up the same place oil runs down. The pushrod tubes.
Old Jul 27, 2020 | 05:52 PM
jonuphi's Avatar
jonuphi
I vented my crankcase on my 18 after my 1st engine sumped at 7000,have almost 22000 on it now and have never felt a hint of sumping on this engine.i run it a half qt down also that's where it levels out and doesn't drip out the vent,seems to work for me
Old Jul 27, 2020 | 07:03 PM
60Gunner's Avatar
60Gunner
I vented my Sporty out the cam chest after blowing rockers cover gaskets 3 times in 1000 miles and head gaskets weep on the dyno after a build and realizing the problem was my stock umbrella valves were shot. Drilled and tapped a hole in the cover for a 90° 1/8 npt fitting and ran the Hayden Krankvent. I plugged the head breathers with solid bolts. Problem solved and no more hoses dangling from the heads.
The difference was immediately noticeable on startup the way idled even. There's a detailed write up with pics on the XL forums on this. Quite a few Sporty owners, especially with builds, run this mod. I haven't done anything with my Softail yet.
Here's a pic. It was pretty much hidden too.
Old Jul 28, 2020 | 06:05 AM
prodrag1320's Avatar
prodrag1320
if you did vent it it with the dip stick (really no difference in venting there or the cam chest) it would not make getting rid of the head breathers a good idea,run them both
Old Jul 28, 2020 | 09:05 AM
twincam10353
Pro, how do you vent your personal street bike?
Old Jul 28, 2020 | 11:56 PM
60Gunner's Avatar
60Gunner
Venting out the hose that vents the tank to the cam chest resulted in excessive oil being vented out during hard braking when the oil level reached that fitting at tiimes according to a few that did it on the sportys.
I havent got into the oiling on these twincams much yet but on the sporty evos venting out both ends wasn't necessary when the and the consensus was scavenging could be an issue in a motor that already had scavenging issues. In fact I replaced the pump with the Buell/07+ pump with bigger scavenge gerators as it was.
I'm just not sure how much wet sumping might be an issue with the TCs. Why I haven't done anything yet.
If you vent out both ends, post how that works out. Personally, eliminating the stock breathers if possible is a plus imo.
I assume Prodrag is venting out both ends without any issues so.
Old Jul 29, 2020 | 06:02 AM
prodrag1320
i just tee`d into the breather hose from the motor to oil tank (2002 & 2005),on the later bikes,i vent thru the OEM dipstick,no reason to spend 100.00+ on a fancy dipstick breather
Old Jul 29, 2020 | 11:59 AM
60Gunner's Avatar
60Gunner
What are you using for a one way valve?
Old Jul 29, 2020 | 01:29 PM
Campy Roadie's Avatar
Campy Roadie
That right there.
Without one you'll draw air into the crankcase.
