Maintenance questions
Old Aug 1, 2020 | 06:16 PM
Marinechamp's Avatar
Marinechamp
1st Gear
Default Maintenance questions
I bought a 2007 Harley Electra Glide 3 yrs ago with only 10,000 miles on it. I rarely ride it. Once last year and 3 times this year. It has 11,700 miles now. The 10,000 mile maintenance was done on it before I bought it. I probably won't put another 5000 miles on it in 3 more years. I may ride it a mile to church or a 5 mile round trip to town every now and then. My question is, do I need to do any maintenance on it before 15,000 miles since it will be forever before I hit that? Am I doing any damage to it by not riding or cranking it often? Someone told me I needed to at least ride it around the block once a week to keep everything lubed up inside or condensation would build up. How can I best take care of this bike if I don't ride it much? Thanks
Old Aug 1, 2020 | 07:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Give it to a friend who will ride it.
Old Aug 1, 2020 | 07:20 PM
Tony_N's Avatar
Tony_N
You need to ride it long enough to bring it up to full operating temperature to keep it from building up condensation in the oil.
Old Aug 1, 2020 | 07:24 PM
Marinechamp
1st Gear
I figured I would get a couple responses like that before I ever joined the site. Now that that's out of the way, I'll wait for the real advice. 😉
Old Aug 1, 2020 | 07:29 PM
pgrchaplain's Avatar
pgrchaplain
Sell it to someone thay will Ride It! Best advice I've got.
Old Aug 1, 2020 | 09:05 PM
NODYNA's Avatar
NODYNA
In addition to riding it long enough to heat the engine/oil to evaporate the condensation as often as possible a yearly oil change is a must do. I strongly suggest fuel conditioners and a battery tender.
Old Aug 1, 2020 | 09:34 PM
Ed Ramberger's Avatar
Ed Ramberger
Short trips like that are killing it. It needs to be ridden to temp for several reasons. If those are the only trips you will make, you need to be on an accelerated oil change schedule, and will probably be changing plugs more often because they are seeing a lot of rich start up conditions.
DO NOT start it once a week and let it run for a few minutes - that only builds up condensation and shortens the engine and oil life and the battery (if not kept on a tender) Oh yeah, keep the battery on a tender!
Old Aug 2, 2020 | 05:13 AM
Marinechamp
1st Gear
Default Thanks
Some good info. Thanks
Old Aug 2, 2020 | 05:25 AM
Lammy1000's Avatar
Lammy1000
Sell it. The bike deserves better.
Old Aug 2, 2020 | 12:24 PM
Pantera99's Avatar
Pantera99
Yes get it fully hot when you ride it, more frequent oil changes, seafoam in the gas, check tire pressure & move it around occasionally so the tires don't get flat spots. Battery tender...why aren't you riding more frequently? I have 3 bikes & 2 quads so some of them do sit alot.
