Zippers 468 cam upgrade. Oem oil pump or..
Old Sep 23, 2020 | 12:40 PM
Socalledchad's Avatar
Socalledchad
Default Zippers 468 cam upgrade. Oem oil pump or..
I'm going to install a 468 in my 107 m8 this winter. 2019 sg Feb 19 build date. I did a quick search and found some older threads..but
If i wanted to update to the latest harley pump do I just need to get the pump with the seal ? Or do I need to also get a new cam plate?
I have read many folks are not having issues doing some engine work with stock oil pump.
Previously I was going to go with the s&s pump...but 33k miles later I haven't had any issues...then i read some have had over oiling issues with the s&s ?
Just trying to figure out if I should drop 600 on a pump or if its just a waste for me. dealer said 150 for the lattst pump but they weren't clear about the cam plate.
Old Sep 24, 2020 | 10:49 AM
twincam10353's Avatar
twincam10353
Just get the S&S oil pump and cam plate kit and be done with it, it is $655 at J&P cycles right now.
https://www.jpcycles.com/product/220...BoCEoYQAvD_BwE
Old Sep 25, 2020 | 08:15 PM
rdc401's Avatar
rdc401
2020 pimp should be fine just like the dealer told you.
Old Sep 25, 2020 | 08:32 PM
MTBIG G's Avatar
MTBIG G
Had the S&S pump and plate on my 18 without issue. The new S&S pumps have the seal so as log as your crank runout is good the S&S would be a great choice. Honestly though for the cost, the 2020 HD pump is a fantastic choice as well... especially for a cam only upgrade.
The 2020 HD pump will work with the older cam plate, but I'd verify that with your parts dept first.
Here's an excellent vid showing the difference between the 2020 HD pump along with the latest offerings from S&S and Fueling.
Old Sep 26, 2020 | 05:25 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We have yet to use ANY fancy red, or blue pump or plates, on any of the multitudes of the M8 cam install/tunes here, contrary to popular beliefs.
T/C's.......maybe 10 in last twenty years......all upon customer request, unless damaged, and then a Daytona pump.
Reminds me of the "unleaded seat conversion" valve jobs of yesteryear.
Scott
Old Sep 26, 2020 | 01:39 PM
60Gunner's Avatar
60Gunner
What's the reasoning behind this fad?
Old Sep 26, 2020 | 01:47 PM
Socalledchad
Fad? Replacement of oil pump ?
Old Sep 26, 2020 | 02:01 PM
djl's Avatar
djl
Unless really pushing the envelope on compression and TQ/HP, the OEM pump, TC or M8 is quite adequate and most of the builds seen on this forum don't fall into that category. Not dissing the aftermarket hardware; all good stuff and the bronze, blue and red cam plates are really pretty but the money can be spent on other things that may not be as pretty but will increase performance.
Old Sep 26, 2020 | 03:57 PM
60Gunner's Avatar
60Gunner
Yes. Like what is the perceived benefit? Curious how this all got started. Why do you think you need that oil pump and cam plate?
Old Sep 26, 2020 | 06:45 PM
Socalledchad
Ok..that makes sense. maybe i shoukd ask myself that. I think in the earley stages of the m8 the oem pump was questionable to start with. But now it seems thats not an issue?
NickF723
Milwaukee Eight (M8)
46
Dec 7, 2019 02:12 PM
Jonesy82
Engine Mechanical Topics
Nov 24, 2019 10:15 AM
Ridetothehill
Feb 13, 2019 12:42 PM
Md8181
16
Feb 6, 2019 07:53 PM
magnum629c
Nov 21, 2011 10:49 PM
