Boring Cylinders to 98"
Old Feb 16, 2021 | 07:30 AM
  #101
Fat11Lo's Avatar
Fat11Lo
Originally Posted by tinymike66
Here's lab results
I'll take it for what it's worth, Pure Hybrid is correct about proper sample techniques. but that wasn't possible in your situation.
The water doesn't bother me, it's not off the charts and temperature fluctuation will cause condensation, how long has the top end been apart and how much has temp changed since then? If you are heating your work space and then letting it cool to sub freezing temps.......
If it were mine I would clean out best you can, having the cylinders off at this point is a big plus, I would flush the case with a solvent of choice and start sourcing parts to put it back together
As an aftercare plan I would change the oil + filter frequently at first and sample as you do, educate yourself on proper sample technique and track your results as long as your numbers stay good you're in the clear and you will have a baseline of what's normal for your engine
Old Feb 16, 2021 | 11:44 AM
  #102
tinymike66's Avatar
tinymike66
Since late December
Yes I will flush it out...do a few oil changes for sure
And def will monitor it.
Everyone's help has been much appreciated and extremely helpful
Old Jun 1, 2021 | 09:18 AM
  #103
tinymike66's Avatar
tinymike66
Update, Update, Update!!!
Hi just wanted to throw an update out there. Been a while.
Sorry for repeatative questions ...sometimes I get the assurity bug and I know it's annoying
Anyways
So all in all....I needed a crank .. I was able to source a rebuilt crank for my model with the double taper Timken bearing, S&S pin, plugged, welded and trued.
I had noticed way to much play in the front connector rod and didn't want to chance it
The shop installing my new crank messaged and said my old crank was shot...the inner pinion race was spinning and the crank was not rebuildable in the future.
Told him I wanted back anyway as shop decor.
I decided to pull oil pan and clean. Absolutely no debris air anything in their...was happy to see this.
I should have the build done withing a week and will post
Had to send Daytona twin tech back. Wasn't working...another on its way.
Thank to everyone who chimed in to help.
Very much appreciated
Clifton63
Exhaust System Topics
Apr 12, 2016 10:11 AM
Gordon61
Engine Mechanical Topics
Mar 21, 2016 06:40 AM
freud
Shovelhead
Dec 11, 2013 02:26 PM
jdusty21
Ironhead
Jun 29, 2007 12:31 PM
Teddy
Mar 8, 2007 08:08 AM
